Question about eMachines etower 366is PC Desktop
Start-up problem with emachine 366i
Emachine 366i running Win98. Will not start when green panel button is pressed. If I unplug AC from wall, wait 30 sec. or so, then replug; machine will start when green power button is pressed. Any fix I can perform? Thanks.
    President:
  • 1,851 Answers
Replace the power supply - but before that - remove every card in the machine and remove the ram too - clean the end of the ram with a pencil eraser - reinstall.
Clean the rest of the cards with a pencil eraser and reinstall.
Blow all the dust from the machine with a can of AIR - get the power supply and fans real good - put it back together and if it works - fine - if not - replace the power supply.
Posted on Apr 30, 2010
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | Dishwashers
Flashing light on front panel will not boot
Unplug the unit from the power at the wall socket. Wait one minute, Reconnect. Retry. Beyond that you'll have to check the hardware: memory, motherboard, internal power supply control, CPU, oh, and the microswitch behind the On button
Jan 16, 2014 | eMachines eMachine EL1333G-03W Refurbished...
Proform tredmill starts runs 10 sec and beeps twice and stops
I would suggest unplugging the unit from the wall and waiting 30 second and plugging it back in. Then go to where the AC cord enters the machine and look for a reset button or switch. Put it in the reset position and see if this solves the problem. Depending on model the reset may be on the bottom of console.
Dec 15, 2013 | Proform 520 Trainer Folding Treadmill...
My emachine em350 battery is not fully charging. it started by charging to 89% then 86% now its at 65% I bought it 5 months ago. What should I do?
Here's how Dell
recommended a reset. First, power down and remove baterty. Second, unplug
AC Power adapter from computer AND wall. Third-Wait till green light goes
out. In my case, went and got coffee and watch a show. Fourth plug adapter
into wall and computer and power up WITHOUT the baterty installed. After
boot up, insert the baterty. It worked?!!?!
Sep 07, 2011 | Acer eMachines 350-2074 Netbook
May tag 5000. f35 what does that mean
"F35" means Analog Pressure Sensor Failure
If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
Hope this helps.
Jul 09, 2011 | Maytag Washing Machines
How do you turn-off the printer. I press the green button, but the light stays on and the printer does not turn off. Is there an on-off switch elsewhere? Maybe inside the printer?
Please press and HOLD the on/off button next to Scan on your printer for 30 seconds until the printer turns off.
If no luck, I am afraid the printer is locked, so please unplug it from the WALL outlet, wait 30 seconds and plug it back. Let me know if the problem is solved this way.
Thank you
TechSaver
Feb 06, 2010 | HP Officejet J5780 All-In-One InkJet...
My PS2 Slim will not start. The power on light is
do this:
unplug the AC cord from the wall and wait a couple minutes before plugging back in.
hope this helps ;p
please rate solution
Jan 04, 2010 | Sony PlayStation 2 (PS2) Console
Ink carts are full. cannot get to reset w/o the ! pt flashing. HP J3680
Hard Reset
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds then replug the power cable to the wall out let and then to the printer.
Power Drain
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds now press and hold the power button on the printer and replug the power cable to the wall out let and then to the printer after the power cable is connected you can let go off the power button..
Partial Reset
Power Drain
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds now press and hold the # and the number 3 button on the printer and replug the power cable to the wall out let and then to the printer after the power cable is connected you can let go off the buttons..
Aug 11, 2009 | HP J3680 Officejet All In One Printer
Problem with emachine m5124 startup
Take the battery out and unplug the power cord. Press down the power button continuously for a solid 30 seconds without stopping. This drains all the power out of the circuits and resets whatever invalid state your computer is in.
Now, leave the battery out but plug in the AC and turn on the laptop. If it works, turn it off again and insert the battery. All should be well.
Jan 25, 2009 | E-Machines eMachines Desktop PC
Shutting down is running across my screen
Do This: Performing a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 03, 2008 | HP Photosmart C7280 Laser Printer
eMachines etower 366is PC Desktop Logo
114 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
