Question about Panasonic DMR-EH50 DVD Recorder
DMR-EH50 "Please Wait" message... unit won't operate.
I moved one mile down the road (literally) and packed my DMR-EH50 in its box and moved it myslef in my car along with other fraginle and important items. When I got to my new home, I set it up and all i get is a "Please Wait" message... nothing else, no matter how long i "wait" I have tried reset (hold power button for 10 sec). That only gets me to clock display but as soom as I try to power up, "Please Wait" comes back. This was almost 1.5 years ago. I called Panasonic.. they told me to ship it to them and they would fix for $130.00 flat fee... I was disgusted so I put it in its box and stored it... Now I am itching to get it going... any advice? Is there a simple fix? I literally used this machine maybe 50 times and it was brand new! Thanks.
  • Joe Jefferson
    Joe Jefferson Dec 09, 2013
    I had this problem and holding down the power button for 10 seconds returned me to the clock. Please wait came back for about 15 seconds and then the problem cleared itself, Thanks. I'm glad it worked for me!s
  • 3 Answers
SOURCE: Does the DMR EH50 work with satelite tv
Yes Connect using Scart
Sat to EH50, Sat to TV as per page 15 of the manual and it should work fine mine does
Posted on Dec 21, 2007
SOURCE: Panasonice DVD Hardrive recorder
See Hiker DC post worked for me.
Posted on Apr 19, 2008
SOURCE: DMR-EH50
try to plug your dvd player into a different tv port !!!!
good luck
Posted on Nov 04, 2008
SOURCE: DMR-EH50 DVD Recorder
Check your user guide for the answer.
Posted on Nov 17, 2008
ravichetty
  • 158 Answers
SOURCE: Panasonic DMR EH50 will not power on. All
REPLACE THE PSU REGULATOR- STRG6353A
Posted on Aug 03, 2009
Panasonic DMR EH50. Picture is dominated by the colour pink. TV not affected.
Please check your Blue and Red component cables on both the recorder and your TV. One is probably loose.
Apr 07, 2014 | Panasonic DMR-EH50 DVD Recorder
Freezes Panasonic DMR-EH50 DVD Recorder issues
Use a TDK lens cleaner to drive off moisture on the electronic circuit.
Feb 23, 2012 | Panasonic DMR-EH50 DVD Recorder
While trying to save parts of a TV-programma I recorded on mij Panasonic DMR EH50 DVD-recorder I try to delete the parts that are'nt useful to me. The recorder gives the following message: Can not 'work'...
Highlight the recorded program on Direct Navigator then press the Sub Menu button on the remote, then select "Shorten Title". Press (Enter) at the start point and end point of the section you want to erase, then use the up/down button to select "Next". Then, select "Erase" to delete the unwanted sections. Repeat this process for all unwanted parts, then select "Exit" to return to Direct Navigator.
Nov 01, 2010 | Panasonic DMR-EH50 DVD Recorder
We have a Panasonic DMR-EH50 DVD player/recorder. We recently moved house and following the move, the FUNCTIONS button on the remote no longer works. Everything else on the remote does. I've tried...
The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Apr 04, 2010 | Panasonic DMR-EH50 DVD Recorder
Actually I have a 4 yr old dmr eh50 panasonic dvd recorder
Make sure remote is set to unit code ex: press enter and 1 at same time see if this matches try enter and 2 or enter and 3 see if this matches and works
Oct 03, 2009 | Panasonic DMR-E50 DVD Recorder
Looking for the region codes!
I want to make my panasonic dmr-eh50 to multi dvd region player. How to get the dvd multi region code?
Jun 24, 2009 | Panasonic DMR-EH50 DVD Recorder
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
DMR-EH50
Check the cable eventually try a replacement cable.
Nov 04, 2008 | Panasonic DMR-E50 DVD Recorder
DMR-EH50 DVD Loss of TV Guide and Auto Time Update.
http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/DVD.ASP
the firmware and instructions are located there.
Jun 26, 2008 | Panasonic DMR-EH50 DVD Recorder
Dec 05, 2007 | Panasonic DMR-EH50 DVD Recorder
Panasonic DMR-EH50 DVD Recorder Logo
231 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
