Question about Epson Stylus DX8400 All-In-One InkJet Printer
Epson8400 red does not show on a nozzle check . I have changed cartriges ran head cleaner still get just a smalllittle line or dash on nozzle check. when I try to print something the Red comes out a greeniish yellow?
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 30, 2010
How can I remove the head/change the nozzle on unidentified vacuum?
Search Results
    DC28 Cleaner Head Replacement Removal - YouTube
    ? 17:19
    https://www.youtube.com/watch?v=yERbv8owKU4
    Apr 2, 2013 - Uploaded by AllVacuumBrandsCTN1
    DC28 Cleaner Head Replacement Removal ... Dyson DC28 Animal - King of Vacuum Cleaner For Pets Hair ...Missing: nozzle ‎unidentified
    Dyson DC24 - Replacing the cleaner head (Official Dyson ...
    ? 0:55
    https://www.youtube.com/watch?v=PeI8N2SuXkM
    Sep 29, 2011 - Uploaded by AskDyson
    How to replace your Dyson DC24's cleaner head. ... Our brush bar reset guide shows how to remove the ...
    How to replace a Henry floor tool on a Numatic ... - YouTube
    ? 0:47
    https://www.youtube.com/watch?v=AUEaFIIFmeg
    Apr 15, 2010 - Uploaded by eSpares
    For all your Numatic vacuum cleaner spare part go to http://bit.ly/1G0FaXS If you've cracked the floor tool ...
Jan 27, 2016 | Vacuums
Air in inkline epson 7600 pro
When u change the printhead on this unit you must be very sure that u unplug it from the wall before u remove the ribbons.t is important that u disconect the line in question from the damper. Take a serenge and start priming the line, make sure ur cartrige is in place, don\'t worry u wil not lose the ink. Prime that thing until u see no more bubbles . Re connect the damper and once that\'s done prime the damper until its full, connect to head Andy should have a working line. If ur serenge is full of ink u can inject it back in the cartrige. Do not do this while printer is on or u will invite more bubbles.....mike
Mar 21, 2013 | Epson Stylus Pro 7600 InkJet Printer
Clogged print head
Put the black ink cartrige nozzle in warm water and wait several minutes.I don't know if this will work in your case but you should try it. I had similar situation and this helped.
Dec 15, 2011 | Epson Stylus Pro 4800 InkJet Printer
Lines show up throughout print jobs
Your print heads most likely need to be cleaned.
When you don't use your ink carts for a while, when you get new ink carts that have been stored in warehouses for a number of months, or when you have refilled a slightly too dry ink cart, the print head nozzles on the bottom of the ink carts get clogged with dried ink. The printer head cleaner menu will not disolve the dried ink. Water will. Try this. Soak the bottom of the clogged ink cart in 1/2 inch of hot water for 15-30 minutes. Blot dry with clean paper towel(you should see the ink color on the towel). Retry.
Mar 07, 2011 | Dell 942 All-In-One InkJet Printer
My nozzle check keeps showing broken lines but I've run the head cleaner like 5 times. The black is a new cartridge and even it has broken lines.
The most likely cause is that some of the print head nozzles are blocked with dried ink and inserting new ink cartridges won't fix this problem. You need a new print head.
Print heads are not cheap, you may be better putting your money towards a new printer.
Jan 09, 2011 | Epson WorkForce 600 All-In-One InkJet...
Hi, (MX850) My blue ink has stopped printing. I
Performing Maintenance:
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
Step 1
Printing the Nozzle Check Pattern.
If lines are missing or if white streaks appear
Step 2
Print Head Cleaning.
If the problem is not resolved after performing Print Head Cleaning twice
After cleaning the Print Head, print and examine the nozzle check pattern (Step 1) again.
Step 3
Print Head Deep Cleaning.
If Print Head Deep Cleaning does not resolve the problem, turn off the machine and perform another Print Head Deep Cleaning after 24 hours. If the problem is still not resolved and if you are sure that the ink didn't run out, then the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
All the best.
Mar 11, 2010 | Canon PIXMA MX850 Multifunction Printer
How to change the cartridge
head clean, then nozzle check then head clean again until the nozzle check pattern looks right. If you get no ink at all by three clean cycles change the cartridge again
Jan 08, 2010 | Epson Stylus NX400 InkJet Printer
Black prints with lines through it. Have ran
Call Kodak. They have printer head problems and they should replace them for free. They ship me one for free, (my wanranty was over) and it work like a new one.
Sep 30, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
When printing a red line appears about every 8mm through the all of the page i am useing a epson rx630 fred
It means some nozzle not perfect. If you check nozzle, there is missing lines for some nozzle. Example : Print blue color ( 100% cyan + 100% magenta). If some point of cyan head is clog, the output will be shown that at some lines just show magenta. It repeated. Yous said every 8 mm, so, you must print it at best photo quality. If you have print at best photo quality, and lines still appear, it must some nozlle badly clog. Try do head cleaning, wait for 30 minutes. Check Nozzle.
Jun 25, 2009 | Epson Office Equipment & Supplies
Problems with color prining
hi!!!!
perform maintenance and
try to clean up nozzles may be the ink
clog
or removed the cartriged and clean with alcohol
use cotton buds then placed it back properly
Oct 31, 2008 | Canon BJC 2100 InkJet Printer
Epson Stylus DX8400 All-In-One InkJet Printer Logo
183 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
