Question about Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only
My model 603 filter pump leaks at the top under cap
My model 603 filter pump leaks at the top under the cap. We replaced the cap and the filter still leaks. What is wrong? The pool and filter pums are only a year old.
  • 640 Answers
It could be the o-ring on this model. There is a seal on these pool filters that looks like a rubber ring inside the lid. You might need to replace this ring if your pump is leaking here.
Posted on Sep 08, 2010
Intex 603 pool filter leaks
make sure top cap oring ok and uniton on front of pump tight
Jul 02, 2017 | Intex Pool & Spa
I have a1984ford ranger. starts right up runs great for 15 20 sec. Replaced fuel pump( external) maybe canister fuel filter?
You always replace the filter before you replace the pump. You probably have a clogged filter and replaced a pump that wasn't bad. Filter is under drivers door mounted inside of frame. A sharpie marker pen top can be cut and slit to fit around fuel line at filter. This will allow you to release the filter from the line. There is a tool for this but a sharpie cap and a pair of pliers works better. Put pen cap beside filter connection to judge lenght. Cut off and slit. Use pliers to insert.
Dec 06, 2015 | Cars & Trucks
I have a intex model 603 filter pump that keeps tripping the reset on the plug... it seems that when i first hit reset it will work for a few mins but then trip.. i can hit reset again and it will work...
Have you tried running an extra duty extension cord to another plug, not in that circuit?? Your GFCI may be bad?? Pump drawing too many amps and the breaker not rated for those amps.. Bad pump??
I would try another plug first and work from there...
Aug 24, 2011 | Intex 603 Krystal Clear Filter Pump 530...
Kenmore Elite HE3 - Washer stopped - door locked - did not drain and spin - Getting error message F02
  1. Unplug the washer.
  2. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer.
  3. The drain/filter/pump is right in front.
  4. You can see a diagram of the pump at http://www.repairclinic.com/PartDetail/Drain-Pump/1200164.
  5. First remove as much water from the washer as you can. Place a large towel under the pump - a lot of water will come out when you remove the filter cover cap.
  6. Remove the drain filter cover cap by turning the filter cover cap counterclockwise.
  7. Remove the filter and check the housing and pump impeller vanes for debris (see if you can move the pumps impeller by hand).
  8. Clean the cover cap gasket and the gaskets mating surface.
  9. Replace the filter and close the cover cap firmly.
  10. Run a short wash cycle and check for any leaks at the filter cover cap. If the error comes back, you may need to replace your drain pump.
  11. Replace the kick panel if none are found.
Feb 27, 2011 | Kenmore Washing Machines
Water leak from top drawer. Had F1 flood alarm
Top right corner: it means the bad right actuator could not pull down the lid seal on that side causing a leak. The actuators are sold in pair. They are not expensive. Replace both of them when you order them in. Need to inspect the rubber seal around the top lid since if it is distorted another 60 bucks to get a new lid for replacement also. The new lid comes with the york to engage with the actuators.
May 08, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
I have a 1994 Toyota Celica, lately when im in neutral the rpms begin to drop and when i give it gas the car stalls out or it stays under 2 rpms after second gear.
Look and listen for vacuum leak Free,Change air filter $15, change fuel filter$20, replace fuel pump$300.
S
With motor running and your head under hood listen for hissing sound. Then start replaceing filters first air filter , then fuel filter. Check fuel pump by listening for humming noise at gas cap when you first move key in ignition to on (when the red lights go on). Have someone listen for you at the gas cap.(NO hum need pump)
Jan 21, 2010 | 1990 Toyota Celica
OVERHEATING EVERY NOW AND THEN WITH COOLANT COMING OUT OF OVERFLOW BOTTLE
Inspect the following: 1.(typical on these models) Possible cooling system caps leak allowing coolant to escape and air into the system. Replace if leaking (there are 2 caps- one cap on the top LH side of the engine and one on the radiator) 2. Radiator fan- This fan on the V-6s are hydraulic driven via powersteering pump, inspect for fluid leaks and proper fluid levels. (To test fan speed, unplug the switch located on the powersteering pump and rev motor to 2000 rpm fan should pick up speed)have it checked if problematic. 3. Replace the thermostat if this hasn't been done in the last 30,000miles, possible binding or stuck (located on the LH side of the engine, under the alternator and at the back end of the coolant feeder pipe). If these all check out fine, inspect or replace the water pump. To replace the pump it requires timing belt removal and or replacement. Hopefully this helps
Aug 03, 2009 | 1992 Toyota Camry V6
Brand new filter pump leaking
If it is brand new and leaking, it sounds like your pool filter has a connection problem. Check your connections to make sure that they are tight and sound and that you do not have any hairline cracks.
Jul 16, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only Logo
1,010 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
