Question about Miele S514 Solaris Turbo Plus Vacuum
Miele Solaris height adjuster arm won't snap back in
Trying to figure out a problem with my Miele Solaris Turbo Plus 234/236 powerbrush, I started taking apart the powerbrush. I figured out the problem but now I can't get the height adjustment bar back in. I figure something inside must catch the metal part that dips into the bottom of the powerbrush, but I can't see any likely mechanisms when I open the powerbrush bottom up. And it doesn't seem to snap in. I don't remember how I took it out...seems it just snapped out. Am I missing a piece? Any help would be appreciated, as this isn't my vacuum!
  • Anonymous Mar 17, 2014
    powerbrush height won't change
    President:
  • 1,673 Answers
Maybe this picture will help, put the pieces together, then it sits directly under where #230 in the pic.
Posted on Mar 29, 2008
  • Scott Nolde
    Scott Nolde Aug 15, 2014
    Any chance you could post a larger picture of the parts schematic?
SOURCE:
Miele S514 Turbo red light on. Dismantled and cleaned. Motor checked and no resistance. Circuit board? Can it be be replaced or by passed?
If there is a circuit board between the cord and the motor it is certainly replaceable. Unfortunately my suppliers don't have schematics for the Miele models. You might try the Miele website, if there is one, or call your local repair shop to see if they service them. Sorry I can't be more help.
Jun 14, 2014 | Miele S514 Solaris Turbo Plus Vacuum
How to reset the Miele Type HS 05 Model S514?
Hi bud
sounds like ps3 has shut down as the gpu/cpu has popped of the board due to over heating and the use of lead free solder.there are places you can send it for repairs or you could have a crack at if with heat gun and liquid flux if your brave. Google it for a tutorial
hope this help you out
Jun 10, 2014 | Miele S514 Solaris Turbo Plus Vacuum
Miele turbo s514 power
If it has no suction take bottom peice off take out brush roll then run clothes hanger through dust channel to clear any blockage if none there its in your hose
Mar 27, 2013 | Miele S514 Solaris Turbo Plus Vacuum
My turbo plus does not turn on when plugged in. This is the first time this has happened. Any suggestions?
Check the power switch, plug cord and vacuum wiring. A open circuit will cause that and you need a continuity tester to test it. Once you find the trouble part, replace it with the same size and rating. A dent or vent wire will cause not to flow the current and voltage so check it.
Thanks for asking.
Jul 13, 2011 | Miele S514 Solaris Turbo Plus Vacuum
Hi a curve piece of wire or metal fell out of the handle when taking it apart.Can`t figure out where it goes?
If it is about 2" long , it is the snap ring almost right at the end in the narrowest part which keeps the extension tube in place .
If it is about 7" long , It is the antistatic strip which sandwiches between the 2 halves of the handle underneath.
Hope this helps.
Jan 03, 2011 | Miele S514 Solaris Electro Plus Vacuum
Miele Solaris won't turn on after falling down 1 stair.
there is no reset on this model. look @ your miele info & it shows you where it would be. I just had to look for mine when it would'nt start. mine ended up being cord winder kink affecting motor.
good luck
linda
Mar 15, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Miele vacuum cord reel question
I had to take off the cord reel and clean the contacts inside it. I also bent the contacts out since they tend to wear down after time.
Jan 23, 2009 | Miele S514 Solaris Turbo Plus Vacuum
Miele solaris turbo plus S514 will not start in live outlet
The reason why the vacuum will not start is because of the cord winder. They are pretty tricky to repair yourself. A service center could probably fix it for about $50.00. It has been a while since I have worked on one of these but I think the screws are under the switch and maybe the filter.
Jan 19, 2009 | Miele Vacuums
Miele Solaris Electro Plus will not turn on
I was using my Miele Solaris Turbo plus to **** the air off the Space Bag. Now I have the red indicator on and the vacuum cleaner won't turn on. Please help. This is my favorite vacuum cleaner!
May 17, 2008 | Miele S514 Solaris Electro Plus Vacuum
Miele S514 Solaris Turbo Plus Vacuum Logo
894 people viewed this question
Top Miele Vacuums Experts
Colin Stickland
Colin Stickland
Gerry Harvey
Gerry Harvey
Allen
Level 1 Expert
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
