Question about Cell Phones
My sim is in to puk mode - Cell Phones
How can i get my sim out of blocked mode
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways -The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.For details to obtain the PUK code for the SIM card, pleaseclick on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
Mar 23, 2012 | LG TracFone 600 Cell Phone - TF600GP4
Hey..!,do you know samsung sgh x700 fdn mode puk code....?
These directions are for an AT and T phone, but other than that would be the same for any carrier.
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your phone carrier to unlock your SIM card.
You can obtain your phone's PUK code from your carrier in one of these ways:
Log in to Your account.online
Use a Technical Support Chat
Contact your carriers Customer Care
Get Your Phone's PUK Code Online
Go to the Phone/Device page.
From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading.
The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator
Sep 17, 2011 | Samsung SGH-X700 Cellular Phone
Get me a new security code of nokia 7210
The PUK code is not related to the handset. It is associated with your SIM card. When you enable the PIN in your SIM card, every time you switch on your phone, you will be asked for your pin. At given number of tries provided by your mobile operator, that you have provided the wrong PIN (usually operators set it at 3 tries), then you came to the stage called PUK-blocked.
To unlock, you would need the PUK code of the SIM card. The PUK code is usually an 8-digit code. This PUK code should have been provided to you when you purchased your SIM card. Some has the PIN-PUK code printed in the card body of the SIM card, while some attach it as a separate print out. Should your operator failed to provide this PIN-PUK code to you, you would have to get it from your operator. Try calling their customer service. Just like the PIN, the operator as well could say how much tries do you have to successfully unblock the PUK of your SIM .
Mar 14, 2011 | Nokia 1100
When I tried to put a password on sim lock I put the password i.e. 3391. Then asked put the PUK code. Again I put the password 3911. Then again asking PUK code. Then the phone is still that condition. ...
PUK stands for Personal Unblocking Key. This is a uniqueeight digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Dec 30, 2010 | Cell Phones
Unlock the puk code for aircel perpaid
PUK or pin unblocking key, usually comes up together with your sim card, be it on a paper, receipt or at the back of your sim card card. it is usually the unblocking key for your pin. normally, puk is for your sim card not to your phone, but, if the phone depends more on the sim, either if you remove the sim and open your phone, it will not open. usually, this is possible for phone who don't have an offline mode. if you lost your PUK, then, the possible way to acquire this, is to contact your network provider and ask for your puk code. if your phone has an offline mode, try inserting a sim that the pin is not activated and check.
Feb 21, 2010 | LG KG800 Cellular Phone
Puk code for a w377 mobile
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call your phone service company, they can retrieve the puk code from a database for free.
In your case you need to contact your SIM card phone provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
Mar 09, 2009 | Motorola Mobility W377 Met Silver/Pink...
T-mobile puk code
The puk code is sim card spesific it comes with the sim card when you get it or you can get it by calling your phone service provider of the sim card to get the puk code.
if you have entered the puk code wrong too many times you will make the sim card useless and you will have to contact your phone service provider for a new sim card, it will probably cost.
Nov 19, 2008 | Sony Ericsson K770i Purple 3G Camera...
Puk codes
When you enter a wrong Pin code three times, the phone goes in lock mode, and ask you for the puk code.
The puk code was enclosed with the original sim card documentation.
If you lost it the only ways to recover the PUk code are either paying a phone shop (they will phone virgin), or calling virgin mobile customer service by yourself. They will ask your personal details, and retrieve the PUK code from database.
Nov 08, 2008 | Computers & Internet
Unlock code of classic 231
I have a classic231 mobile set, i use ruim card at the present time, so i want to be now use virgin card so please help me and send me unlock code on my Email ID- manojkumar.nkp@gmail.com
Mar 21, 2008 | Timex Fashion Classics 23161 Wrist Watch
I can't open the phone lock and my sim card is also turn in PUK mode
Hi
Jan 02, 2008 | Sony Ericsson P990i Cellular Phone
Cell Phones Logo
48 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
