Question about Lexmark X6150 All-In-One InkJet Printer
Printing problem printer is showing deleting pr- message
    Genius:
  • 3,587 Answers
Restart computer...reinstall drivers from here
Posted on Mar 25, 2008
Wont print
click start, right click devices and printers , click open, right click printer image, click trouble shoot, follow instructions, If no joy and you have the disc, remove from the hard drive and reinstall .
Feb 05, 2016 | Canon PIXMA MX472 WIRELESS OFFICE...
Maintenance ink pr
Can you please explain what is happening, are there any error messages or what happens when you try to print etc.. the more details the better. Thanks
May 31, 2013 | Brother MFC-9320CW Color Laser Printer -...
Hello: I removed all installed printers from the uninstall list in control panel the other evening. Then I deleted two icons from the devices and printers window but they sometimes reappear. This time, I...
Hi Edward
The automatic reappear printer problem its come when you are connect to two and three computer in same network, when the network on the automatic search the printer in network if you install that printer in any other PC so automatic the printer is add in your printer list.
For installing the printer not nee to delete the all printer, put the installation CD in Rom and click the setup.exe
Cheer
Jul 11, 2011 | Xerox Phaser 6180N Laser Printer
Trying to print a picture from my dell computer. when i hit print on the computer printer does not print. what button do i push on the printer itself. when i go to view/print it just says to insert memory...
With the printer power on, unplug and then plug in the printer from/to the computer. This should force the printer to be reinstalled.
Check the printer status.
Click START>Control Panel>Devices and Printers>click on your printer. check the status for any error messages. On the printer status, delete all pending jobs. Once the printer status display shows that all pending jobs have been deleted, retry printing.
Let me know if printing is reestablished. Thanks.
Mar 15, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Print error on print report and am using win 7 and usb virtual port 1 What is the connection problem as the demo prtout on the printer works ok
Main causse of printer failer is printing interruption and corrupted files for driver.
Solution 1. Check for the device manager to see some error in hardwares especially the usb port. If there is reinstall the missing driver because maybe it is corrupted.
Solution 2. Most printer error can be resolve by uninstalling and reinstalling the printer software.
Solution 3. Maybe the is confusion on the buffer and he does not recognized the printing files. Try no to print usual character that will make printer to confuse. To solve this:
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your pr
Dec 24, 2010 | OKI C3200n Led Printer
Printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 18, 2010 | Panasonic Workio DP-3030 Printer
Cannot delete a print job
restart the computer
while the computer shows the BIOS message, turn it off, wait 2 minutes. Turn on again
Apr 01, 2010 | HP PSC 1315 All-In-One InkJet Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Error code 6A00
TThere is a prblem with the carriage lift mechanism.
Probale causes
1.PR Lift shaft assembly
2.Sheet Feed Unit
3.Logic Board
Send the printer for repair ,
Apr 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark X6150 All-In-One InkJet Printer Logo
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
