Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
When hit switch pto won,t come on
When turn elertic pto switch on deck wont engagewhen hit switch pto won,t come on
  • 29 Answers
Check the 2 wire conection under the frame near the pto clutch, motor off of course. Make um tight.
Posted on May 01, 2010
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
Toro 11-32 won't start.new battery. i jump the terminals it fires right up. 2nd problem is the deck won't engage I hit the switch and nothing I leave the seat it shuts off when engaged
Check and see if the Engagement termnal on the solenoid is getting power. If it is replace the solenoid.
As for the PTO check for at its connector for voltage. If voltage is there check for about 1.7 ohms resistance across pto coil. If it reads infinity or less than 1.5 ohms replace the pto clutch assembly.
If the pto reads less than 1.5 and there is no voltage at the connector than the pto switch is probably burned up due the shorted pto.
May 14, 2015 | Toro Garden
Pto not engaging in john deere lx 167
Check the voltage on the wire(s) connector to the PTO switch. Sometime portion of the switch can go bad. If you have voltage coming in to the switch check the output voltage going to the clutch..
Apr 03, 2012 | Garden
John Deere 160 Mower Deck Switch - mower deck does not engage when switch is turned on. The "dead man" engine shutoff still functions when the switch is engaged - if the switch is on and there is...
Hi, check that you have 12 volts to the pto when the switch is on. It sounds like your pto is fried as the switch is functioning correctly. Regards Phil.
Sep 20, 2011 | John Deere Garden
Just replaced pto clutch brand new ,wont engage.nothing, zip not a movement.
Check that you are getting voltage to the wires that connect to the clutch when you switch on the pto. If not check that you are getting voltage to the pto switch. If you are the pto switch is faulty. Regards Phil
Apr 15, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Jul 06, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
1,175 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
