Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
No suction vacuum working fine and suddenly, no suction at all....what could be the problem? no suction through the machine from either the wand or the floor/brush side
  • Anonymous Mar 16, 2014
    I have suction in the wand, but I cannot reattach it to the back of the vacuum
  • 20 Answers
Sucked up a sock?? No seriously.. it may be as simple as that or that an on board filter is clogged. Check your manual for all filters and Hepa/screens and others. Also, is the unit making any odd noises since the non -suction scenario? Whining or screeching sounds, where is the motor impeller/vac bearing or similar is damaged or a hose is kinked within hte unit itself.. <not normally unless the unit has been taken apart and placed back together and crushed the main return vac hose. .
Posted on Apr 30, 2010
Dyson no suction in upholstery wand
Hi there, it's Jack at Dyson.
Like most Dyson upright vacuums, DC18 is engineered to divert suction to the hose and wand automatically when it's standing in the upright position. If your DC18 doesn't seem to have suction from the wand when standing upright, you may have a blockage in the hose or wand. Please follow the steps shown in our online Support guide to check for this: http://www.dyson.co.uk/support/dc18/dc18-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/no/remove-the-wand-from-hose
It's also a good idea to give the filter a wash - in normal use, this should be done at least once every 3 months as shown in the video below. Use cold water without detergent, and allow at least 24 horus for the filter to dry completely before replacing it.
I'm confident following these steps will resolve the issue. However if you'd like any further guidance from our experts after you've given this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 27, 2014 | Dyson DC18 all floors Bagless Upright...
Wand suction getting activated - Dyson DC40
Is the vaccumm on or off when you put the bin back ?on?
Apr 13, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Shark transformer vac model ep602 will not suction from the floor brush, but will suction from the flexible hose. Dust cup and filters are clean. Do I need to replace the floor brush? Unit was purchased...
Has the floor brush ever worked for you? I thought it was broken at first too. The hose has to be inserted in the appropriate hole in the side of the machine. The hose is where all the suction comes from, when you put it in the side hole it will provide suction for the floor brush.
Oct 11, 2010 | Vacuums
Vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Sep 11, 2009 | Kenmore 22512 Bagged Canister Vacuum
Dyson all floor vaccum no suction when hand held wand is turned on... doubled checked for cracks in hose -- none took house off unit to check for blockage --- none.. suction works fine when using as normal...
You need to replace the belt that drives the brush on the underneath side of the vacuum. To do this, you need to flip the vacuum over and remove cover plate. There you will find the broken, or stretched out belt. Remove the brush and place the new belt on the chrome axle. Then put the brush on, rapping the new belt around the brush as you put the brush back in place.
Jim
Jun 09, 2009 | Dyson DC14 All floors Bagless Upright...
The suction works in the wand, but not in the main vacuum
Sounds like you got wraped up in your work..
You need to take the bottom plate off and expose the brush. Once you in side you can unwind the mess. You should change the belt at the same time. Good luck. DFD
May 03, 2009 | Vacuums
Suction in Wand Only, (No suction down below).
check the small hose that is under the machine ( it connects to where the brush roller is ) also you can remove a u shaped tube near the bottom of the machine and also another on the right side of the machine near the bottom as well
Sep 08, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Suction not working in upright
Hi.
You will have A blockage in either the wand or hose, completely remove them from machine the hose unclips at the bottom back of machine,
Now switch machine on with this removed if machine sounds ok then remove the blockage from hose or wand.
If machine still poor suction & noisey with hose & wand removed check the (U) shaped inspection port for blockages.
Let me know how you get on.
http://dysonmanuals.llc.nu/index.htm
May 17, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
470 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
