Question about Samsung RS2630SH Side by Side Refrigerator
The freezer fan makes a very loud noise
The freezer fan on our samsung RS2530B makes a very loud noice
    Problem Solver:
  • 7 Answers
It probably has ice build up around i. Try manually defrosting it. Unpluggit and let it thaw out.
Posted on Apr 30, 2010
Why it make loud sound like fan is thatching some metal when i plug in?
check the fan blade to make sure it is tight on shaft. also check to see if any of the fins are bent could be that they are hitting the housing of the fan motor.
Jun 07, 2014 | Turbo Air MUF-48 M3 Series 2 Door 48"...
Samsung rs2530b refrigerator making loud noise...why?
It might have dust in it. It can drain the fan speed, which makes odd sounds. It could be something else jammed in there too. Clean the fan and see if that works.
May 28, 2012 | Samsung RS2530B Side by Side Refrigerator
Making loud gurgling sounds only when door is closed. Have called for service but 5 days away and this is constant
the loud noise come from the fan in the back of your freezer unit , but if you not expert i wouldent open the unit b/c Fisher and Pyk are very sensative units and if you do something wrong or put something wrong they wont work.
the noice is the fan that might be bad or tuch something like ice...
hop it will help you
Jan 08, 2010 | Fisher and Paykel Active Smart E522B...
Freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Jun 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
Refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Nov 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Ice build up and loud noice when fan comes on
you have a defrost proble you will need to acess the timer and advance it to defrost post the model number so i can direct you most likely your heater is out in the evaprator
Apr 05, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Samsung RS2630SH Side by Side Refrigerator Logo
460 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
