Question about Samsung CLP-510 Laser Printer
I utilize a Samsung CLP-510 printer which presently has a yellow toner that needs to be replaced per the menu screen on the unit. I believe the drivers are installed correctly, however, I cannot print from the unit at all at this time. Any suggestions?
    Problem Solver:
  • 17 Answers
You need to replace the yellow toner. There maybe a option in the menu of the machine for "toner out" and it maybe on stop if you change it to continue it could work for a while. "If the printer has that option". Most color printers will not continue to print if one of the cartriges are empty.
Posted on Apr 30, 2010
Samsung CLP 510 just replaced transfer belts, imaging unit and fuser but now am getting what looks like wet spots on the prints
Some toner may have spilled in the printer. If so, you will need to clean it out. Also, the toner cartridge may be defective and letting too much toner out at one time, the solution is to replace the toner cartridge.
Take care.
Jul 20, 2010 | Samsung CLP-510 Laser Printer
Imaging unit needs replaces per message
Yes, but be careful about where and how you dump the toner. It can make a real mess!
Aug 22, 2009 | Samsung CLP-510 Laser Printer
"invalid toner cartridge" message remains
Try this
Turn the printer off hold down the menu button turn the printer back on while continuing to hold down the the menu, when you get a green light your ready to print
Feb 18, 2009 | Samsung CLP-510 Laser Printer
Samsung CLP 510 Imaging Unit
The Imaging unit needs to be replaced when the drum fills up with waste toner. That's what triggers the message.
Feb 02, 2009 | Samsung CLP-510 Laser Printer
Wrong clp 510 toner
samsung clp 500 toner cartridge can not use samsung clp 510
bcase clp 500 is without chip and clp 510 chip base cartridge so never u can user.
Dec 27, 2008 | Samsung CLP-510 Laser Printer
Samsung clp-510n
there are ways to reset the counters on the toner so that you can continue to print.
See:
http://www.dunfield.com/clp510/
Oct 28, 2008 | Samsung CLP-510 Laser Printer
Toner ink
The printer needs to think it has all 4 toners present, and NOT at the end of their life.
There are two methods of achieving your goal of using this as a mon printer only.
1 - a zero cost option which works on a CLP-510, and may work on CLP-500.
Hold the MENU button down whe you switch the printer on. The printer will then start up in 'UNCHECKED CONSUMABLE' mode. You will have to remember to do this each time you turn the printer on.
2 Just replace the reset fuse modules on the Yelllow, Magenta and Cyan cartridges. Much cheaper than replacing the cartridge.
In both these cases, of course there's no more toner in them. but provided you ONLY print mono this shouldn't be a problem, and there's probably an option in the printer driver to set it for mono anyway (but the printer still needs to 'think' it has usable colurs cartridges in it).
Aug 29, 2008 | Samsung CLP-550 Laser Printer
Samsung CLP-510 Toner Bleed
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
Jan 09, 2008 | Samsung CLP-510 Laser Printer
Toner and Imaging Unit issues
If this IS a CLP-510, first make an information confirmation print.
Press MENU, then press ENTER, and ENTER again.
Look at the counter for the imaging unit, is it a low count confirming that you have indeed replaced it ?
If not you will need to reset the counter.
Check the counters for the toner cartridges, and check the capacity of the cartridge. On a CLP-510 the image counter for the toner is held on the chip on the cartridge (which also identifies the capacity of the cartridge).
There have been some faulty (oiginal Samsung chips), and of course re-manufactured cartridge chips could fail (many re-manufacturers don' test their cartridges before dispatch, they don't have the facility to do so without starting the count on the chip (or 'bowing' the reset fuse on a CLP-500 cartridge). VERY few re-manufacturers can test these cartridges without starting the count.
Sometimes the 'replace xxxxx toner' messages are caused by toner on the three contacts on the side of the cartridge, or their mating contacts inside the printer. Rarely, this can be caused by a faulty circuit board.
Dec 20, 2007 | Samsung CLP-510 Laser Printer
Samsung clp-510n printer
1 Could be toner on the contacts (inside the printer) that mate with the contacts on the cartrdige.
2 Are you sure they are 510 toners and not 500 ones ?? 510 toners have a chip that identifies the cartridge (Colour, Capacity) and maintains a count of the pages printed.
500 toners have a reset fuse that resets the toner counter in the printer, and a resitor that identifies the capacity
3 Are they new cartridges, remanufactured, or 'home refiled'.
if either of the later two, were the chips replaced ? - if not the cartridge still thinks it has printed its full life of pages.
Nov 28, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Laser Printer Logo
144 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
