Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Starting my bike
battery gets hot to touch when trying to start my bike.i have a 883 sportster bored to 1200.1992 it seems that the starter is not ingaging all the way.and then i get a clickin sound.and then nothing.can you help please?
eddie
    Scholar:
  • 150 Answers
First off bro the 883 does not become a 1200 by boring the cylinder. there is absolutely no difference in the size of the cylinder of a stock 883 or 1200. to make the displacement bigger by 317 cc's the head dome is made larger. you can make any 883 a 1200 by carving out the inside of the head to increase the volume. to make this increase in displacement by boring the cylinder would require making the inside of the cylinders bigger than the outside which obviously can't be done. your starter is probably getting hot due to poor electrical connection. most likely in the ground pathway. if you dont have good continuity the amps go way high and the starter gets hot. you can have all the voltage in the world but if you can't carry the amps then the thing will click and and overheat. check your cables and make sure no corrosion also if you painted your bike then the paint on the frame needs to be scuffed off where the ground strap connects
Posted on Apr 21, 2008
883 sportster 2007, bike will start on compression but will not start with switch, speedometer needle is stuck and flashers does not work.
Hi, Sylvain before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
07 883 Sportster Won Start
Harley Davidson Sportster Workshop Service Repair Manual 2007 $8 very cheap includes a $60 electrical diagnostic manual
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/007-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Jul 30, 2017 | 2007 Harley Davidson XL 883 Sportster
I have a 86 sportster 883 and put a new battery in and it wont start.
Hi Anonymous, this question has already been asked and answered. Thank you and have nice day
Dec 12, 2013 | 1993 Harley Davidson XLH Sportster 883
Relay switch start
Hi Ahsanmsa, when you are trying to diagnois anything in the starter circuit you must start with a fully charged battery of 12.5 volts or better and will pass a load test of 9 volts or better while cranking the engine over and the cable connections are clean and tight especially the negative cable at "BOTH" ends. If you suspect a faulty starter relay check it for continuity and/or swap it with your horn, brake, or system/fuel pump relay temporarily, if the bike starts with no problems replace the bad relay. Good luck and have nice day.
Oct 01, 2012 | 2009 Harley Davidson XL 883 Sportster 883
I have a 883 harley davidson sporster, was riding the bike and road over a bump and bike shut down and won't start
I'd check the battery first. I've seen the post break loose from the batteries in many Sportsters and leave them dead on the road. I've only seen this happen once on a Big Twin. Why? I have no idea. If nothing on the bike works, this may be the problem. If everything else works but it just won't start, I need more information. Does the starter engage and the engine turn over?
Steve
Aug 13, 2011 | 2000 Harley Davidson XL Sportster 883
93 HD Sportster 1200 will not start!
Have you tried to bypass the starter button/switch? Use a heavy jumper wire to go between the starter terminal and the positive battery terminal. Turn the key to "On" position, make sure "Run/Off" switch is turn on. Make sure bike is in neutral. I've started guys bikes with coat hangers before when they lost had trouble with the starter button. If the bike starter turns over, you'll at least have a place to start looking for the issue. Also you said you checked the battery, what was the voltage?
Jun 02, 2010 | 2001 Harley Davidson XL Sportster 883...
No start problem on 07 883 customer sportster. When I hit the starter it either starts or when it does not start you can hear a click like a relay switch. 3 moths ago harley dealer replaced a relay do to...
You need to determine if the solenoid is delivering power to the starter motor terminal when it just clicks. You need to have either a test light or a voltmeter to read 12 volts DC. If, when it clicks, and the meter shows 12 volts at the starter terminal, then the starter motor is in trouble (it could be bad brushes or an open segment on the armature commutator). If you see no voltage, then check the battery side of the solenoid to see if the normally present at all times 12 volts disappears when the starter is tried. If that is so, check the battery cable for a bad wire or connection all the way to the battery. If it stays 12 volts, then the solenoid is bad and should be replaced. Hope that gets you started!
Sep 26, 2009 | 2007 Harley Davidson XL 883 Sportster
Harley Davidson 883 2004
I have a 1980's somthing 883 with a fucked up hand built wiring harness and for some strange reason when I hit the starter it just clicks. So I moved the relays and got shocked. Whats my problem???
May 25, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
135 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
