Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
What is the proper 115 volt wire connections for an FP5162-01
The manual illustrations so not resemble the wiring setup on the pump
  • 126 Answers
On the pressure switch just make sure the two whites are on one side and the two blacks are on the other side.Line is the house power and the load goes on the other.
Posted on May 17, 2010
Where do the wire leads connect to the switch?
Look on the id plate on the motor, and inside the cover on the back and inside the switch cover.
Jul 03, 2015 | Utilitech 1/2 HP Convertible Jet Pump...
Wiring a single speed 230v 5hp ao smith pump: what wire goes to terminal B, L1, L2, A
L1 and L2 are the posts to hook up to, there is no polarity so either way works,
Oct 06, 2013 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
Proper wire hook up
black goes to L1 white goes to L2 make sure to look on side of motor to change from 220 volt to 110 volt either a knob or changing wires brown and white to different locations hope you didnt fry motor
Jul 26, 2013 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
115v electrical hookup for dayton motor 1TMY6
Dayton manufacturing is owned by WW Grainger
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1TMY6&op=search&Ntt=1TMY6&N=0&GlobalSearch=true&sst=subset
Contact Grainger 1-800-323-0600
They will have wiring information for each of their products.
The wiring diagram should appear on side of unit.
This 1.5 Hp motor can be wired for 115 or 230 volts
My AO Smith manual would not be specific to your motor.
With AO Smith 115-230V, there are one set of wiring terminals for incoming wires from breaker box. The other wires connect to terminals.
Copy following illustration link:
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Wire and breaker size:
For 120Volt, use 20 amp breaker and 12 gauge wire up to 25 feet.
Over 25 feet up to 100 feet, use 30 amp breaker and 10 gauge wire.
100-150 feet use 8 gauge wire and 40 amp breaker.
150-200 feet use 6 gauge wire and 50 Amp breaker.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 28, 2012 | Dayton Permanent Split Capacitor Motor Fan
Dayton motor 1tmy6 electrical hookup
You can contact WW Grainger
Sep 28, 2012 | Dryers
Wiring a 230/115 1 hp 56y pool pump motor
please verify the name plate to be 115 230 volt motor.there will be a schematic that shows you exactly how to hook up this motor depending on the voltage being supplied to it. The main thing is switching between 115 and 230 volts this is a selector switch this very easily forgotten about. Please make sure to check that and double check that to make sure its on the proper selected switch. Good luck
A thumbs up would be greatly appreciated if this answer is helpful to your free Fixya question
Jun 30, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
I'd like to know how to change a 115/230 volt pool pump motor to run on 115 volts after I've already change to internal possition to 115 volts
IF YOU SEE ON THE LABEL ON THE MOTOR HOW TO CHANGE FROM HI - LO VOLTS . THATS ALL YA GOT TO DO ..THE WIRES HOOK UP NORMALY
May 21, 2010 | Hayward 3/4hp Super Pump Inground Pool...
The pump is wired for 110.after it runs for 3-5 minutes it starts to smoke.It can be used at 110 or 220.Is it wired wrong?
Thank you for posting your question here on Fixya.com.
The nameplate on the side of the motor will show how the wires inside the motor are to be oriented for whatever line voltage you are supplying to the motor. The wires you bring in as line leads go to the same posts no matter if you are hooking up to 115 or 230 Volt 1~ AC power. Be certain you have your two line wires and your ground wire where they need to be and that the motors internal wires are set for 120. Most motors are shipped setup for 230 so if this is a new pump and you did not rearrange the internal connections for 115 it is likely the cause of your problem.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jan 18, 2010 | Waterway Svl56 1.0 Hp 1 Speed Energy...
Wire Hayward Super Pump for 115
If you look closely, you should see a small arrow on the black plastic piece on the terminal block(jumper). That arrow lines up with either the 115 or 230 mark on the white terminal board. Make sure it is aligned with the 115.
Then put you two line wires on. It does not matter which wire goes to line 1 and line 2, just be sure you DO NOT put them both on the same terminal. A plastic divider usually seperates the two line connection terminals.
Jun 13, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
265 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
