Question about HP Hewlett Packard LaserJet 3800 Printer
My cassette tray is stuck and cannot be removed on my HP Laserjet 3800
  • Core71 May 02, 2010
    I fixed it. Had to remove the following parts.
    Front door and duplex assembly
    Top cover and Fuser.
    Left side cover
    Feed assembly
    The problem was caused by a tab on the cassette drawer that had snapped. Printer works now, however I probably will get a replacement for the tab.
  • 153 Answers
Ask some one who knows about printers well.
Posted on Apr 30, 2010
Tray lifting error hp printer hp laserjet m5035mfp
The tray lifting error is displayed as 60.02 Tray 2 lifting error. To fix this error, check the surface sensor of the paper tray2 in the Manual Sensor Test 2 menu under the Troubleshooting menu.
Connect back the cassette lifter motor and the DC controller PCA's connectors and now, replace the filter driver unit in your printer.
123 hp com Quick HP Printers Setup Easy Installation Guidelines
Dec 16, 2011 | HP LaserJet M4345 MultiFunction Printer
Trying to print using my new hp Laserjet 2420 yet being told error printing. The printer shows tray 2 is empty yet it has some papers. Is there a way to only use tray 1 if the tray 2 cannot operate...
Tray 2 paper senor not sensing the paper either it may dusty,failed or sensor flag mis placed.. verify where is the fault..Location: remove tray2 cassette, under you can observe the paper sensing flag..
Aug 30, 2011 | HP LaserJet 2420 Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
The printer is printing slow about 15ppm
On the paper cassette tray (Tray 2) there is a blue lever on the right side. The paper tray must be removed prior to this inspection. This lever indicates either custom or standard size paper. Make sure this lever is parallel with the cassette tray side. There is a diagram near this lever indicating where it should be. Meaning this should be set for standard paper. This can slow the printer down dramatically if set at custom when standard letter or legal is in the tray.
Oct 16, 2009 | HP LaserJet 4250n Printer
Setting tray 2 as default
In paper handling set tray 1 to CASSETTE
Feb 05, 2009 | HP LaserJet 8100n Printer
Paper pickup in tray 2 not working
This is an issue i've seen many times.
The gear that drives the lower tray barely conacts the gear in the main body.
You cannot buy just the gears, you will have to buy a new option cassette assembly.
If you lift the printer off of the lower cassette you'll see the suspect gears.
Dec 19, 2008 | HP LaserJet P2015dn Printer
Hp 4700n
Have you would try a different paper cassette.
Usually that clunking noise is associated with gears not mashing.
Is the lifter lifting the platform or not?
There might be something above the paper tray, maybe even the paper input assembly preventing the paper platform from reaching the top.
Check these and let me know what happens.
Oct 03, 2008 | HP LaserJet 4700N Printer
HP Hewlett Packard LaserJet 3800 Printer Logo
150 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
