Question about Kenmore 64802 Top Freezer Refrigerator
The fan located in the back of the freezer section is not working
The freezer is working fine but the cold air is not getting down to the fridge. I took it apart and found that the power is getting to the fan but it is not coming on. I tested the fan seperately and it would not work. Is there a temp gauge that kicks it on? There are three wires going to it and one is a ground.
    Problem Solver:
  • 7 Answers
Your fan needs to be replaced.
Posted on Apr 30, 2010
Kelvinator cyclic 410 Upside Down Fridge Freezer. Fridge not getting cold. Freezer is working fine.
Is the fan in freezer compartment working? Is the damper fully open to allow cold freezer air into fridge section?
Sep 23, 2017 | Refrigerators
I have the refrig where the freezer is on the bottom, the bottom is working fine but the top is not getting cool.
a common problem with bottom mount freezers is the door gets left open,open the freezer door and look at the ceiling,is there ice on it and is there also frozen water droplets on the packages,if so the door was left open,you can shut the fridge down or unplug it,remove the food from the freezer,get a hair dryer and blow the hot air onto the back inside wall of the freezer mostly blow it into the open slots in the back wall,it will melt the ice that's in the air ducts,you'll see water dripping down,when it stops you can start the fridge and stick your hand in the top middle of the fridge section to feel if cold air is blowing in,all that it does is there's a fan in the freezer,all it does is blow the cold air from the freezer into the fridge section,if the door was open the warm air gets in and mixes with the cold air and it freezes up the air ducts and blocking them.if this isn't the problem open the freezer door,you should hear the fan blowing,if not you could have a bad fan motor,also put your hand on the back inside wall of the freezer,if there's like frost or snow on the back wall you have a defrost problem,a bad defrost heater,defrost thermostat or timer or board depending what the model is,but most of the time the problem is behind the freezer inside wall,or depending on your model there could be a damper in the fridge section,if it's stuck closed then the cold air won't blow into the fridge section.so first open the freezer door,listen for the fan,if it's blowing,check for frozen water droplets and ice up on the ceiling near the light and on the food packages,if you see this the door was left open,if the fan isn't blowing most likely it could be bad,then check the back inside wall for frost or snow on it,if there's frost on the back wall you have a defrost problem,most likely it will be a bad defrost thermostat or heater,you'll need to check them with a maeter,hope this helps,next time send the model number so i can look up your machine.
Sep 04, 2011 | Maytag Refrigerators
Freezer is working fine. Bottom Control for Crispers working fine. Upper section of fridge not getting cold.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
May 26, 2011 | Frigidaire Refrigerators
My bottom freezer gets cold but the top part (fridge) does not. Why? I have an older first addition style
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
May 19, 2011 | Amana ABB1927DE Bottom Freezer...
My refrigerator side isn't cooling the freezer is fine on my GE Monogram Model zisb42dca
Possible faulty freezer fan motor. Dirty condenser. Faulty control board.
Feb 23, 2011 | GE Refrigerators
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
Jul 03, 2009 | Refrigerators
Fridge not cooling
Check and see if your evaporator fan motor is working in the freezer. Also, if your defrost system is not working and your evaporator coil is frosted up, you will not get any cold air to the refrigerator section. You should see alot of frost on the back wall of the freezer where the evaporator coil is located. If your evaporator fan motor is working and there is no frost build up on the coil, the air diffuser to the refrigerator section may be the problem. Put your hand in front of it when the evaporator fan motor is running and feel if any air is coming thru. There are a number of conditions that can cause your problem. This should get you started! Visit me on Ebay as username: themackshack. Good luck! Mack
Mar 23, 2008 | Refrigerators
Cold freezer warm fridge.
That sound was the evaporator fan motor in the freezer. This circulates the cold air from the freezer into the fresh food section. If this is not running you need to check for power to it. If the fan has power to it but not running, replace it. It should be located behind freezers back wall inside of freezer near top.
Oct 09, 2007 | Refrigerators
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 64802 Top Freezer Refrigerator Logo
148 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
