Question about HP LaserJet 3380 All-In-One Printer
How do I dismantle the printer to access the scanner bed?
    Problem Solver:
  • 18 Answers
You can get perfect info from this link
INFORMATION
Posted on Apr 30, 2010
How to scan a slide on flatbed scanner
This model Canon MX700 cannot scan slides.
A flat bed scanner that can scan slides and negatives has a light scource that shines through the slide and negative fand is detected by the scanner sensor.
I suggest you purchase a slide scanner, it will be cheaper that getting a new flat bed scanner with slide capability.
May 17, 2012 | Canon PIXMA MX700 All-In-One InkJet...
Scanner grinds when powers on
Its not drivers issue, hard ware issue.. Scanner assm faulty,replace it..For tech guys:Open flat bed glass, remove scanner assm clean inside reflector glass with ear buds & adf glass especially at home position.. lubricate on rail refix it back.. check it..
Dec 22, 2011 | HP Photosmart C4580 All-in-One InkJet...
Can you scan negatives on a flat bed scanner?
You can only scan negatives on a scanner that has a second light source in the lid of a flat bed scanner. This light shines a light through the negative and the main light source under the glass is not switched on for negative scanning.
Jun 02, 2011 | HP OfficeJet J4580 All-In-One Laser...
Error 5010
You have a scanner error. Most likely its a dirty sensor under the scan glass.
You would need to partially dismantle the scanner bed and clean the home
sensor. A tricky proposition without the right tools.
Mar 23, 2011 | Canon PIXMA MP600 all-In-One InkJet...
I cant seem to find where i load the ink cartridge into the printer
1. Raise the scanner bed and position the scanner support to hold the bed up, exposing the printer cartridges.
2. Press down on the tab on the end of the cartridge cover to open the cartridge bay. Pull the old cartridge straight out of the bay and properly dispose of it. Remove the tape and stickers from the new cartridge and insert the new cartridge into the bay.
3. Press the cover down until it locks in place, securing the cartridge. Repeat the process on the other cartridge if necessary.
4. Lift the scanner bed to release the scanner support. Lower the scanner bed to close the printer.
Mar 16, 2011 | Lexmark X2350 All-In-One InkJet Printer
Ipls guide me for changing the catridge
  • Turn the printer on and confirm that there is paper in the tray. After the new ink cartridges are loaded, the printer will need to run an alignment test. On the front of the printer, above and to the right of the paper tray, there is an access door that swings open sideways. Open the access door. The ink cartridges will move so that they can be reached through the door.
  • Press both print cartridges down until they pop out of their holders. If you will have difficulty remembering each cartridge's position, remove only one at a time. Once a cartridge is popped out of its holder, it can be lifted freely through the access door.
  • Prepare the new ink cartridges for installation by removing them from the packaging and removing the tape from the bottom of each cartridge. Be careful not to touch the delicate metal contacts on the bottom of the cartridges.
  • Install the cartridges by aligning them slightly below the holders, then pushing them up and forward until they snap into place. Close the access door when you are finished. A test sheet will begin printing to check the alignment of the cartridges.
  • Open the lid of the scanner and place the test page face down on the scanner bed. The upper-left corner of the test page should line up with the arrow in the corner of the scanner bed.
  • Push the "Scan" button on the printer control panel. The scanner will scan the test page into the printer's memory, which will then be used to make any alignment adjustments that are necessary. The printer is ready to use when the test is complete
  • Oct 30, 2010 | HP DeskJet F4280 All In One Printer InkJet
    I have the message "Unlock scan head" when I turn the screw to the left to unlock it, I get the same message. Is there anything else I should be doing?
    If you receive this error even after unlocking the scanhead xerox suggests replacing the scanner assembly. Item Inc offers this part on exchange for much cheaper then xerox. Here's a video to show you how to fix this error/replace the scanner.">
    Aug 05, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
    I dont know how to change the ink cartridge on my lexmark 5500-6600 series
    just near the control panel lift the top portion of the printer which is the flat bed scanner assembly and that should give you access to the ink station
    Aug 05, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
    Clicking nosie from scanner bed on epson cx5800f
    I had a similar problem, the scanner bar was stuck to the far left side. Here's how I fixed it:
    1)Unplug the printer, disconnect any cables/phone lines to it.
    2)Lift up the entire scanner bed housing(you will see the printer ink cartridges).
    3)Locate the access patch (approx 1 cm x 1 cm square) along the left edge of the scanner bed housing(this is the side that closes in, next to the keypad buttons).
    4)Using a small knife blade, peel off the patch from the corners and edges(it's sticky. Save it, you can stick it back over the hole when you're done).
    5)Stick a pen through the access hole, and push the scanner bar to the right, approximately 2-3 inches.
    6)Now, close the scanner housing, plug in the printer, and power it on.
    It should reset and re-calibrate the scanner bar. If it doesn't, repeat steps 5) and 6) a couple times, until the printer correctly performs calibration. Then, you can put the sticky patch back over the hole, and you're ready to go. Hope this helps!
    Jun 28, 2008 | Epson Stylus CX5800F All-In-One InkJet...
    ADF Document Jammed
    Have you tried manually rotating the ADF wheel back and forth, sometimes the sensors are OK but the rotators lose grip.
    Oct 23, 2007 | Brother MFC-8440 All-In-One Laser Printer
    HP LaserJet 3380 All-In-One Printer Logo
    100 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
