Question about Sharp AR-M550N Copier
Trying to network my sharp arm550n, i cannot find where to set a static ip
    Problem Solver:
  • 14 Answers
Press YSTEM SETTINGS button. On screen KEY OP PROG > enter code (00000 default) > NETWORK SETTINGS > INTERFACE > IP SETTINGS. Ensure DHCP is deselected ( touch the tick box to remove tick mark) and enter IP details. Select OK and then press CA button. Reboot machine for settings to take effect.
Posted on Jul 22, 2010
How do you set tablet to static IP?
If you have Android 3.x, use this procedure:
1)Open Settings
2)Touch Wireless & networks on the left
3)Touch Wi-Fi settings
4)Find the network you wish to connect to and long press it (touch and hold).
5)Touch Modify Network
6)Touch the IP Settings drop down and change from DHCP to Static
7)Enter the settings for your network - if you are unsure what settings to use, contact your network administrator
If you are using Android 4.0, then use this procedure:
1)Open Settings
2)Under the Wireless & networks heading on the left, Touch Wi-Fi
3)Find the network you wish to connect to and long press it (touch and hold).
4)Touch Modify Network
5)Touch the Show Advanced Settings check box in the lower left corner of the dialogue box. If the Show Advanced Settings option is not displayed, you may need to go back a step and Touch Forget Network, and then, when you reset up the network, you will see the Show Advanced Settings option
To ensure that you have got Static IP visit IP-Details.com to have an IP lookup.
May 18, 2014 | Samsung Galaxy Tab Tablet PC
How to enable wireless connection on dell latitude e4300
I have had this issue on DSL troubles.The most common issue is the settings for the IP address.A computer in a business location will often be set for a static IP.You can change it,but don't forget to write down the static IP settings(as soon as you click on the "bullet" for "obtain IP address automatically" ,the static info is GONE,and there's no way to retrieve it.Go to control panel/network connections,right click on the NIC or Wi-Fi connection being used,click properties,highlight Internet Protocol TCP/IP,click properties.This will show auto or static IP.
May 31, 2012 | NetGear WGR614 Wireless Router
Need a static ip address
First you go to machine network settings and then DHCP disabled.Now you can using static ip address.
Jun 29, 2011 | Sharp AR-M205 Copier
Trying to open port 3389 in my firewall. Set for UDP and TCP but the tester program still says that they are closed. I have disabled windows firewall. Still no luck.
Make sure you are doing this for the right ip address. The ip address should be your local computer's ip address and will probably look like 192.168.1.x . To get to this go into your network control panel and click on your connection and view the details to get this information. Remember that every time your router resets this ip could change. I would suggest setting a static ip in either the router or on your computer in question. To set up a static IP for windows xp: http://portforward.com/networking/static-xp.htm. For windows Vista:http://portforward.com/networking/static-vista.htm. For windows 7: http://portforward.com/networking/static-win7.htm.
May 13, 2011 | Belkin F5D8236-4 Router
System Error E007
Are you getting this problem while trying to scan , if it is the most probale case is you are using DHCP setting on your pc and the ip address of the pc varies, so the machine is not able to send the documents scanned to the particular IP , to which the machine is configured what you can do is make the IP adress static and reconfigure the scanner by using sharp desk software or you can configure the scanner by giving the host nameof the particular PC if you have a DNS server , better way if you are not so familier with IT you go to network places, then click on view network connections and click on the properties and from the next window scroll down to TCP/IP click on properties and give a static IP, sub net and gate way this nos you can get by going to start menu on the run you type cmd then youwill get the cammand prompt window there you have to type ipconfig /all and press enter then it will give you so much information in which you can find the ip adress, subnet and gateway and give this to your pc and apply, then you open the internet explorer and type the ip adress on the adress bar and press enter then you can go to the machine web page then select administrtor setting the admin username and pass word is admin and admin, and press enter then go to image send settings and configure the newly given ststic ip to the particular PC, rate this and come back withmore queries.
May 04, 2011 | Sharp AR-M350N Copier
I want to connect my SCX 4500w to a new network (wireless). when i try to use a web page to configure the printer settings it doesn't response... I check the IP and write in in my Internet Explorer,...
You could try having your Samsung SCX-4500 print out a network configuration sheet. It will have the printer's IP address, default gateway etc.:
1) Press the <Menu> button on your printer panel
2) Scroll using the (<) or (>) navigational arrows until "Network" is displayed
3) Press the <OK> button
4) Scroll using the (<) or (>) navigational arrows until "Network Info" is displayed
5) Press the <OK> button
Your printer should print out a network configuration sheet. The IP of the printer appears in the TCP/IP information on this configuration sheet.
Note: Your printer's IP assignment should be "Static" not "DHCP" (You may skip the following steps if your printer's IP assignment is already "Static")
To change your IP assignment from DHCP to Static:
1) Open up your Windows browser
2) Type in the printer's IP address in the address (location) bar of your browser:
Example: http://192.160.0.100 (use the real IP you found above from the network information sheet)
3) SyncThru should load - Click "Network Admin" or "Network Settings"
4) Click on the "TCP/IP" option on the left side
5) Change the IP address METHOD to "Static"
6) Click <Apply>, then <OK> or <Exit>
Now your printer is ready to be added to your network. You have the information you need from your network configuration sheet. Your install should now proceed smoothly.
I hope this information was helpful!
Mar 07, 2010 | Samsung SCX-4500 Laser Printer
Force NST icon to show up in the tray.
During installation you should of had the choice to add to start up if not all you need to do is copy the NST to the start up folder. As far as "forcing" ip updates not available. You really need to have static IPs for your pcs. If static not available then you should set up the scan to e-mail option.
Oct 14, 2009 | Sharp MX-2300N Color Copier
Laptops don't have static IP. I want to change the configuration
I think the generic username is Administrator and the password is either "admin" or "Sharp"
Aug 12, 2009 | Sharp AR-M207E Black and White Copier
Setting up a static IP
Hi kellysdad,
Setting up static IP is what we called manually IP or not generated by DHCP. Maybe you where putting the same IP between your bridge and your network TCP/IP properties.
Try to removed your network devices from hardware control panel and installed it again..
Hope this will be helpful to you.
Best Regards,
Philip
Oct 23, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Sharp AR-M550N Copier Logo
439 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
