Question about RTO Lifespan Fitness Tr 2000 Hrc Treadmill
Will not power on
The treadmill tripped the breaker, I turned the breaker back on, turned off the tv that was on the same circuit. I then tried the treadmill again and it worked for a second but this time the whole breaker wasnt tripped, the treadmill just went dead.
    President:
  • RTO Master
  • 832 Answers
The lower board has a serious short and what possible happen is that the treadmill breaker fried and open up will properly need replacing also.
Posted on May 06, 2010
I just put together a Sole f63 treadmill (it took forever). I turned the power button on and the display lit up. I pressed the start button and the display shut off. I can't get the display to turn back...
First of all, make SURE that the unit is NOT plugged into a ground fault circuit interrupt (GFCI) outlet. Make sure that the safety key (or safety tether cord's magnet) is on the round metal portion of the console control's head. (It will NOT operate without this in place because it's a safety feature. Also check the circuit breaker under the console, & push it in until it clicks (if it has been tripped (it would extend out if tripped)). Make sure that the power cord is fully inserted in the appropriate power outlet & that the building/home's circuit breaker has not tripped. Otherwise, call your dealer to replace what would be a defective treadmill.
Feb 22, 2015 | Exercise & Fitness
No power
Check the reset/off circuit breaker located on the
treadmill frame near the power cord. If the switch
protrudes as shown, the circuit breaker has
tripped. To reset the circuit breaker, wait for five
minutes and then press the switch back in.
Mar 07, 2014 | Proform XT 70 Treadmill
I have a Ntl 1094 Track C 1900 and the problem i have is ; the drive motor for the belt trips a breaker in the house breaker box. The belt will start and run for approx 5 seconds and the the breaker...
first check and see what the circuit is rated at. it you have too many thing on that circuit(light,tv,etc) this will trip your breaker because of the amp draw of the treadmill. nordictrack recommends a dedicated circuit of 20amp. you may nned to have a circuit put in with 12/2 wire
Oct 17, 2013 | NordicTrack Exercise & Fitness
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Pro form 365 won't start
Dear Sir:
I will help you, please do the exact step:
PROBLEM: The power does not turn on
SOLUTION: a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor is plugged into a properly grounded outlet (see page 10). Use only a single-outlet surge suppressor that meets all of the specifications described on page 10. Important: The treadmill is not compatible with GFCI-equipped outlets. b. After the power cord has been plugged in, make sure that the key is fully inserted into the console. c. Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch back in.
Finally: check, the breaker from the home, if there tripped, check this, and Reset.
I will recomend when you finally set up, install Stabilizer Voltage, is cheaper us$15,00 aprox
Thank you in advance, sincerely.
Blessing, if you need additional help, please contact me.
E.CUADRA MANAGUA, NICARAGUA.
Sep 26, 2011 | Proform Crosswalk 365 Console Treadmill
Tread mill wont turn on. it was on then while in use the screen flashed on and off then treadmill shut down and has not turned back on. tried reset button then unpluging for a while but still does not turn...
Dear Sir:
Thank you by your problem, I will help you inmediately.
is plugged into a properly grounded outlet . Use only a single-outlet surge suppressor
that is UL 1449 listed as a transient voltage surge suppressor (TVSS). The surge suppressor
must have a UL suppressed voltage rating of 400 volts or less and a minimum surge dissipation
of 450 joules. The surge suppressor must be electrically rated for 120 volts AC and 15 amps.
2)After the power cord has been plugged in, make sure that the key is fully inserted into the console.
3)Check the circuit breaker located on the treadmill
the switch back in.
4)Check the on/off switch located on the treadmill
near the power cord. The switch must be in the on
position.
I hope you resolve this. Otherwise, try to reach me. Inmediately.
sincerely.
E.Cuadra
Sep 13, 2011 | Nordic Track NordicTrack Elite zi...
I have a Proform XT 90 treadmill that was recently purchased. After I brought it home, I plugged into my power strip and everything worked fine. Yesterday I plugged it in and nothing lights up on the...
cocopoi-
A couple likely issues would be:
1. Is the starter key installed correctly?
2. Has the onboard circuit breaker tripped? The breaker reset is next to the on/off switch, which is on the lower front of the unit. Press the button once firmly. If this was the problem, the treadmill should work again immediately. If the onboard circuit breaker trips repeatedly, there may be a short circuit in the machine, in which case you may be at risk of shock if the unit is not repaired properly.
3. Has the circuit breaker or fuse for the particular outlet you are using tripped? Try plugging another electrical appliance into the outlet. Does it get power? If the circuit breaker or fuse has tripped, that particular circuit may be overloaded or faulty. Only an electrician could tell you for sure.
Please followup if you need further assistance.
Regards,
DIYpro
Apr 29, 2011 | Proform Exercise & Fitness
The power is on but it won't run
Power issues with treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Thanks for the rating Good luck
Dec 22, 2010 | Exercise & Fitness
It does not turn on says safe
This message appears when you remove the Safety key.
Kindly provide me with the make and model of the machine?
Are you sure that the key is intact? Is it properly placed?
Thanks!!
Aug 21, 2010 | Exercise & Fitness
Treadmill shuts down and trip off the power outlet when you change the speed
outlet-breaker may be to lower for machine and or may be other things on same circuit lamps,refrigerator,fans etc try a different outlet with nothing else on circuit and at-lest 20 amp breaker ---if power is good than motor in threadmill might need servicing oil or adjustment
Jan 25, 2010 | Proform Crosswalk 500 Treadmill
RTO Lifespan Fitness Tr 2000 Hrc Treadmill Logo
642 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
