Question about Xerox Phaser 6360 Laser Printer
The text on the printer's display shows up backwards, upside down, and when you scroll thru it, things get all cluttered. The printer operates just fine, its just impossible to scroll thru the menus on the actual display. Is there something wrong with a board? The actual display? Firmware?
  • 1 more comment
  • Adam Apr 30, 2010
    Nope. It was purchased used. Just powered it up, control panel shows text that is upside down and backwards, and when you scroll, things get mixed together. Prints fine, but control panel is essentially unusable. I'm guessing it's just a bad control panel?
  • Adam Apr 30, 2010
    Now I powered it off, waited about 1 minute, and powered back on, and the control panel lights up, but it's blank. I have to imagine its a bad control panel.
  • StarrWulf May 11, 2010
    did you take it apart before the problem occured?
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
If your 6360 has a blank display, garbled characters, inverted, upside down, or backwards display the control panel is bad and must be replaced.
Here's a video to replace it. It's very easy and takes about a minute.
Posted on Feb 03, 2011
Before you buy another control panel, take it apart and make sure it is hooked up properly... the display may have been put in 180 degrees wrong (that is what it sounds like). if the control were bad, you wouldnt be seeing anything usable.
Posted on May 03, 2010
How do I create mirror image letters?
I will assume you need to print part of page backwards or upside down.
This is pretty easy using a Text Box. A text box can have a border, be opaque or transparent, force the text to flow around it or not.
To create a text box, go to the Insert tab, click Text Box and then I like to choose "Draw Text Box." You can draw it in the general area you need it. It's ok to use one of the preset Text Boxes, too.
Type your text inside.
To flip the text around, double-click your text box to activate it, and then look for the Rotate button in the "Arrange" section on the Ribbon. You can flip it horizontally or vertically as many times as you need to make your text upside-down or a mirror image.
Then edit your box - border, color, text wrapping, position, etc.
Sep 19, 2014 | Microsoft Office Word 2007 Full Version...
HP LaserJet M5025 MFP scans too light. Under default job options, image adjustment, darkness set to 3. The printer was sent to us upside down. We recently installed a brand new cartridge. Any suggestions?
If you print the configuration pages from the administration>information menu and they look dark then you know that the printing system is working fine. If they are light as well, then it is possible that being shipped upside down resulted in some dirt getting into the laser scanner. The image original settings are kind of wonky, in that it is backwards to normal assumptions. Darkness refers to the actual orignal you are scanning, so in most cases if you have lighter origjnals then you need to set darkness lower. As well, check whether the image type is set for photo or text. Setting for text will result in darker scans.
Jun 18, 2011 | HP LaserJet M5025 MFP Printer
My screen of computer is so big the contents are enlarged my kid has pressed some buttons pls help
Hi nayyarshelly,
I like to help you regarding your concern having big Icons on your desktop, you mentioned that your kid accidentally pressed something on the machine that made everything big, See steps below to changes the Icons or your systems desktop settings.
  • First the system should be turned ON and logged in to Windows, I am assuming that you have Windows7 on your computer.
  • On the keyboard Hold down the CTRL button while holding down the CTRL key on the mouse scroll, scroll backwards this should make things smaller again.
  • If the screen on the Internet is also big do the same thing while your Internet Explorer is open this should change the size of the text / pictures anything on the Internet explorer.
  • But if the above does a different function from what you are experiencing then I believe that you are experiencing some changes in the resolution of the screen if everything is Enlarged.
  • Click on Start then on the search bar type in display, a list will show look for Display then click on it to open up the Display window then click on Adjust resolution.
  • The resolution on your screen depends on how big the LCD screen is
  • On the Resolution page you can pretty much check each resolution on the list that will be better to you, then click on Apply lower right then OK to apply settings on this page.
I hope that this will be of help regarding your concern.
Have a nice day,
mvincentc
Apr 24, 2011 | Computers & Internet
Its upside down? i cant rotate it.
If you are talking about your screen, -- right click anywhere on the desk top background, chose properties. Scroll thru the tabs to > Settings - then to the > Advanced tab at bottom of the window. Now depends on the type of video card you have, but look thru your tabs for the rotate settings.
Oct 09, 2010 | Computers & Internet
Its upside down! novo laptop
If you are referring to the screen, right click on an open area of the screen away from the icons and scroll down and select "personalize", go to "display settings", look in the left pane and look for the text that references "Screen orientation", open this and choose "landscape". click apply and ok.
If you have an older operating system that dies not have "personalize", then choose "properties" and then display settings, then advanced settings, choose "landscape" for screen orientation.
Jul 31, 2010 | Computers & Internet
Viewfinder views things backwards
Yes, most finder scopes show upside down images, it's completely normal.
This is an astronomical telescope. Even the main tube shows upside down images unless you use what is called an "erecting prism" for terrestrial viewing.
Jul 06, 2010 | Meade 70AZ-TR Telescope
The display is reading upside down and backwards.
The display panel has gone bad and must be replaced. This video shows you how to fix it. Very easy and no tools required. hope this helps. ">
Apr 19, 2010 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8560 display error
There is a known issue with that display. Call 1-800-835-6100 and tell Xerox you have a problem with the diaplay, They should replace it free.
Jan 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Monitor 2 - Image is upside down and backwards
Check your graphic card settings. I have a 6600gt, and can invert my screen. Try going: right click your desktop, select properties. Go the settings tab. Clieck advanced. There do you have a tab for your graphics card? Mine shows I have a 6600Gt. After selecting the tab it displays options. I have NVrotate. That rotates my screen.
Jul 16, 2008 | Computers & Internet
Need complete recent call log and more days for text message storage
The call listing only shows one caller by design, to help with clutter on the list. It's a little funky, but if you think about scrolling through pages of the same caller just to find that number to the pizza place again, it makes sense.
If you open Messaging, you can access the settings in the menu there to increase (or set to never delete) text message life.
Please let me know if you get stuck!
Sep 13, 2007 | Motorola Mobility RAZR V3
Xerox Phaser  6360 Laser Printer Logo
306 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
