Question about Canon imageRUNNER 1330 Laser Printer
Said it had a paper jam. pulled out the drum and now it wont go back in?
    Problem Solver:
  • 18 Answers
Please check carefully, as its built of plastic, so be careful. There must be some plastic jacks or rollers, which supports the drum to go in, otherwise if failed then see the manual.
Posted on Apr 30, 2010
How to fix brother printer paper jam error
Follow the steps below to clear the paper jam.
  1. Pull the paper tray completely out of the printer.
  2. Pull the jammed paper up and out of the printer.
  3. Press the cover release button and then open the front cover.
  4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. To prevent damage to the printer caused by static electricity, DO NOT touch the electrodes shown below.
  5. Open the back output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7. After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  7. Close the jam clear cover. Close the back output tray.
  8. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
  9. Put the drum unit assembly back in the printer.
  10. Put the paper tray in the printer.
  11. Close the front cover.
http://support.brother.com/g/b/faqend.aspx?c=hk&lang=en&prod=hl5040_all&faqid=faq00000026_010
Sep 11, 2017 | Brother Office Equipment & Supplies
Paper jams and burn
Lets try the following
  1. If there is no paper, load a new stack of paper into the paper tray.
  2. If there is paper in the paper tray, make sure it is straight. If the paper is curled, you should straighten it. Sometimes it is helpful to remove the paper, turn the stack over and put it back into the paper tray.
  3. Reduce the amount of paper in the paper tray, and then try again.
  4. Check that the MP tray mode is not chosen in the printer driver.
  5. If the LCD shows Paper Jam message and you still have a problem
Or try
  1. Pull the paper tray completely out of the machine.
  2. Use both hands to slowly pull out the jammed paper.
  3. Press the cover release lever to open the front cover
  4. Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
  5. Put the drum unit and toner cartridge assembly back in the machine.
  6. Close the front cover.
  7. Put the paper tray firmly back in the
Or leave a Voice mail we'll check what we can do
Jul 26, 2014 | Canon Genuine Oce Imagistics Fx3000...
Brother 2170W, toner is stuck after paper jammed. I try to pull out the toner (even with force!) but it stuck, there is a paper at the bottom that i can't pull either. I guess this paper holds the...
If the paper get stuck inside the printer you can also remove it fro the back of it. Open the back cover and try to remove the jammed paper inside of the printer. If still the paper can't be remove try again to removed the drum and toner.
Open the front cover or pull down the cover right above the brother logo infront of the machine then hold the handle of the drum and toner assembly.Pull the drum and toner assembly towards you, just put a little force on it. Then remove the jammed paper.
Just to make sure, remove the toner from the drum by holding down the tab on the side and lift the toner out. Look for any small piece of paper inside of the drum unit. Reinstall the toner back to the drum. reinstall the drum and toner back to the machine, make sure that you here a click sound. After that close the front and back cover.
The blue light should lit up again.
Hope this helps. Thanks
May 06, 2011 | Brother HL-2170W Laser Printer
DRUM ERROR - HAD PAPER JAM, CLEARED THAT AND NOW IT WILL NOT PRINT - KEEP GETTING DRUM & ERROR
Sorry to hear you are having problems. Printers can be very frustrating at times. Below is a description of how to complete clear paper jams paper can get jammed it there pretty tightly and in very small places. Ensure you've followed all the steps to clear your paper jam and you should see your printer start working again. Refer to your user guide (or download via the link provided at the bottom) for illustrations.
  1. Open the front of the printer.
  2. Slowly take out the drum unit and toner cartridge assembly. Some of the jammed paper will be pulled out with the drum unit and toner cartridge assembly.
  3. Set the drum unit and toner cartridge assembly on a piece of disposable paper or cloth in case you accidentally spill or scatter toner.
  4. To prevent damage to the printer caused by static electricity, DO NOT touch the electrodes inside the printer.
  5. Close the front cover.
    Note: Do not put the drum unit and toner cartridge assembly back in at this point.
  6. Pull the paper tray completely out of the printer.
  7. Pull the jammed paper down and out of the printer.
  8. Open the back cover (back output tray).
  9. Still looking at the back of the printer, pull the tab toward you to open the fuser cover.
  10. Pull the jammed paper out of the fuser unit.
    HOT SURFACE
    After you have just used the printer, some internal parts of the printer will be extremely hot. Wait for the printer to cool down before you touch the internal parts of the printer.
  11. Close the back cover (back output tray).
  12. On the drum unit you set aside, push down the green lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
    CAUTION
    Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
    To avoid print quality problems, DO NOT touch the roller part of the toner. Try to keep you hands, fingers and everything else away from there.
  13. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the green lock lever will lift automatically.
  14. Open the front cover. Put the drum unit and toner cartridge assembly back in the printer.
  15. Put the paper tray firmly back in the printer.
  16. Close the front cover.
  17. Make sure that the Error LED is now off.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Jan 27, 2011 | Brother HL-2170W Laser Printer
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Dec 21, 2010 | Office Equipment & Supplies
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
Printer jam
Title:
How do I clear paper jams?
Description:
If a paper jam occurs, the Paper LED will flash as shown below.
c_panel_cover_open.gif Caution
    After you have used the printer, some parts inside the printer are extremely hot. When you open the front cover or face-up output tray of the printer, never touch the shaded parts shown below.
  1. Remove the paper tray from the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Open the front cover.
  1. Pull out the drum unit and toner cartridge assembly slowly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
c_hl20_03221.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the back cover.
  1. Pull the tab toward you to open the rear chute cover.
  1. Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull the paper out with other.
  1. Close the back cover.
  1. Push the lock lever down and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
c_hl20_025121.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit and toner cartridge assembly back in the printer.
  1. Put the paper tray firmly back in the printer.
Apr 05, 2009 | Brother HL-2040 Laser Printer
PAPER JAMMED-PRINTER HL5150D
Hello a_bowen1
You can clear the jammed paper as follows.
Note
    • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
    • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
  1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
hl50_05712.gif Caution
  1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Note
    If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
chap0615.gif Caution
  1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
  1. Pull the Duplex Tray completly out of the printer.
  1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
  1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
hl50_047.gif Caution
  1. Put the drum unit assembly back in the printer.
  1. Put the paper tray in the printer.
Good Luck and don't forget to leave a rating based on my solution:
Mark
Apr 04, 2009 | Brother HL 5150D Laser Printer
Paper jam on Brother HL-1270N
Title:
Description:
Feb 23, 2009 | Brother HL-2040 Laser Printer
Canon imageRUNNER 1330 Laser Printer Logo
107 people viewed this question
old marine
old marine
