Question about Garden
I have a mountfield 46R PD petrol lawnmower - two years old. Engine has started hunting / chugging and won't run at high speed. I've changed the spark plug - no change. I've checked air intake - all ok. Any ideas?
  • 37 Answers
SOURCE: mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Posted on Nov 23, 2008
  • 3 Answers
SOURCE: maintenace Manual for Suffolk Punch petrol-driven Lawnmower
Have you checked with the company that makes the mower for the manual? Hae you tried searching the internet to see if you find the manual there?
Posted on Dec 09, 2008
  • 10865 Answers
SOURCE: what fuel do use in the mountfield HP470 petrol
No. This is a 4 stroke engine and it uses regular gasoline, not a mix.
Posted on May 06, 2009
  • 279 Answers
SOURCE: Running problems with Mountfield HP454 petrol lawnmower
First thing to check is the air filter. It may be plugged.
Posted on May 28, 2010
SOURCE: How do I change a worn Carburettor Gasket and
Hunting and erratic operation are signs of air leaks or diminished fuel flow at WOT settings.
If this mower is running a vacu jet style carb with a diaphragm you simply take off the air cleaner, the vent tube, and then the four screws holding the carb on the gas tank and after the carb body can be lifted remove the throttle linkage so you can flip over the carb and pull the main jet and clean the inlet screens.
http://www.psep.biz/store/briggs_stratton_carburetor_kits.htm
Posted on Aug 11, 2010
Champion 35 lawnmower hunts
Clean the air filter (foam type) in warm soap water then apply some oil soaked in, it will smoke afterwards for a short time. Or possible minor adjustment too the mixture screw on the side of the carburetor spring loaded. Allan
May 09, 2012 | Garden
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
How do I change a worn Carburettor Gasket and Diaphram on a SP470 B&S Engine on my Mountfield Lawnmower? I'm good at DIY. The engine is hunting and running erratically.
Aug 11, 2010 | Briggs & Stratton Garden
I have a honda gv100 lawn mower and there is no petrol going to the engine
I have a mountfield omega petrol lawnmower with a gv100 honda engine. I turned it upside down to replace the blade and now it won,t start. Any help would be appreciated
May 30, 2010 | Honda 8 HP Engine
May 28, 2010 | Mtd 22" Yard Machine Push Mower
Ford focus 1.6 zitec petrol, engine warning light flashing, engine chugging, very high fuel consumption, fumes smell when stationary, exhaust seems ok, recently change speed sensor and coil pack?
try the air filter first and the intake.the spark plugs then and after all go to a garage for checking compression timing and the head gasket.
Apr 22, 2010 | 2004 Ford Focus
What fuel do use in the mountfield HP470 petrol lawnmower is it a 2stroke mix?
May 06, 2009 | Garden
Mountfield sp470
Nov 20, 2008 | Garden
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
