Question about Microwave Ovens
Replace door handle Whirlpool Microave. How to take door apart for this? Mod GH5175XPS0
  • gordonwosak May 01, 2010
    No tabs on this door.
    There is a slot near each hinge. I pryed there and the plastic cover began to loosen. I worked it around / out with a putty knife (cracking it along the way) until I could peek behind it near the lower handle screw location. Screw still hidden behind more stuff inside. Hard to find a good exploded diagram . Have a poor quality one from www.partselect.com/WSchematics/Whirlpool/FGVYAO.gif.
    Door appears to be assembled by pressing / snapping pieces in place.
    I called Whirlpool, they said no service manuals available. Do you know of a good diagram with good parts illustrations? Sometimes that tells enough. Thanks Gordon Wosak
    No tabs this door.
    One slot near each hinge. Pryed that and then proceeded to work plastic cover out w putty knife. Naturally, cracked it in the process. Able to look in where lower door handle would be. It is hidden behind more stuff. Couldn't get any deeper without forces likely to break things up, so reassembled.
    Think maybe this door is made of one-time pressed in parts, seals, etc.
    Do you know of a real good quality diagram with good parts illustrations. Sometimes that tells enough.
    Example of design by amateurs. Most heavily worked part of door (beside hinges) is weak and hard to fix. Kids hate to ask old timers how to do things. Prefer to spend 40 years learning the hard way.
  • 11,896 Answers
Open the door, you will see metal tabs that hold the facing of the microwave door, use a flat-head screw-driver or putty knife to pry the tabs so the door piece comes off, then you will have access to the screws holding in the handle
Posted on Apr 30, 2010
  • Nate Stansfield
    Nate Stansfield May 01, 2010
    You can view all the diagrams for your microwave here:
    http://www.partselect.com/AdvancedModelS...
How to replace the door handle on a whirlpool MH2155XPQ micro wave
The screws that hold on the handle are inside the door assembly. Here is the way its done but its not for the average person. On the inside of the door is a plastic frame all the way around the door. It is held in place by plastic tabs. You have to gently pry off that frame with something like a putty knife or small screw driver. If you are not careful you end up breaking off some of the tabs. Once that frame is off you should have access to the 2 screws holding on the handle. Remove screws---replace handle---and push plastic frame back on.
Jun 26, 2015 | Whirlpool MH1150XM Convection/Microwave...
How to disassemble the door of gmh5205xvs-0
On the inside of the door there is a plastic frame that goes around the edge with 2 slots in it that the door latches go through. You have to very carefully pry the frame outward to remove it. First check with a parts supplier to see if your handle is available because some microwave doors are not repairable----you need to purchase a complete door. If the handle is available then attempt to remove the frame as I described before. Once the frame is off you should be able to see the handle screws. If they are still hidden the outer door frame and inner metal door will need to be separated also. They too just pry apart with plastic tabs holding everything together. Replace handle and reassemble. Not hard just time consuming and must be done carefully so as not to break the plastic parts.
Feb 26, 2015 | Whirlpool Microwave Ovens
How can i replace the front door panel that has cracked at handle . it is whirlpool microwave over range
The parts are available from appliance parts houses. They do sell to the general public. I did one a few months ago. I think the outside door was around $30. It is not a difficult job. Just know that you have to take the entire door apart to do the job. 20-30 minutes.
Dec 10, 2014 | Whirlpool Microwave Ovens
The door handle fell off my Whirlpool Microwave Hood Combination - GH9176XM. How do I access the bottom screw for the door handle? Thank you
You cannot. you would have to take the door apart and it's really really not recommended as any tempering with a microwave can lead to a radiation leak from the magnetron. ( it's also the reason why as a customer without a repair license you cannot buy any microwave parts except for filters.)
Mar 15, 2011 | Whirlpool GH9176XM Microwave Oven
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
Handle replacement
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
This should be a very simple repair that you can easily perform yourself.
If you have any questions, please post back and let me know. You can refer to this illustration, if you like, to assist you as well:
http://pcappliancerepair.com/model-display.php
I hope this helps you.
Mar 17, 2010 | Whirlpool GH4155XP Microwave Oven
How to replace the door handle on a mod. MH 1170XSY-0 mico wave
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jul 09, 2009 | Whirlpool MH1170XS Microwave Oven
Replacing door handle of Whirlpool GH6178XP
I kept prying on the frame case until it disengaged, came loose and exposed the bottom screw.
Feb 17, 2009 | Whirlpool GH6178XPS Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
