Question about Magellan RoadMate 1220 GPS Receiver
When i turn on my magellan 1220 the screen freezes at the logon screen and does nothing. is there a way to reset the system?
I'm also having the same problem with the same model. But there is no reset button with this model. Even the manual says nothing about a reset button. Help!!!
Posted on Jul 04, 2010
  • 696 Answers
There is a reset on your unit located on the side, below the SD card slot. A straighted paper clip should do nicely for this procedure.
http://www.magellangps.com/assets/manuals/604-0070-001+A+UM+1200+EUK.pdf
Good Luck!
Posted on May 01, 2010
How do you reset a magellan roadmate 1220?
As a general rule, for Magellan RoadMate models the RESET BUTTON is on the right side inside a small hole; the use of a pointed object (tip of a pencil, a ball-pen, etc.) is required to apply pressure on this button in order to perform the RESETTING PROCEDURE.
You may also can try to hold down the POWER BUTTON for 10 seconds to power off the device; then repeat the same procedure (holding down the POWER BUTTON) for other 10 seconds to power on Magellan RoadMate.
Mar 08, 2011 | Magellan RoadMate 1220 GPS Receiver
My magellan triton 500 will not fully turn on. It statrts to load the bat goes all the way and then freezes. I can not turn it off either.
You need to reset the magellan triton 500, then it will fully come on and stay on. To reset this type of magellan. What you have to do is to take out the battery and reinstall it back in. That should do the job for you, and if that does not solve the problem, then you have to back up the maps on a computer then format the triton then restore the software and maps back on it. Now am assuring you that will do the job.
Hope this information helped you.
Dec 23, 2010 | Magellan Triton 500 Handheld GPS Receiver
When I turn on my magellan maestro 3200 it just says Magellan and stays on that screen . What is the problem ? I just bought the unit from ebay and this is the firt time I'be tried to use it . I read the...
whether its new or used, this can happen for a few different reasons. sometimes they just freeze up there and then they freeze up when someone has tried to update it and the updated failed before it was finished installing it.
hopefully all it will need is a reset...looking at your 3200, look on the left side of the gps and you will see a hole that you can insert something like a paper clip in..turn on your 3200 and insert a paperclip in the hole and gentle depress the reset until the unit restarts...
if it still will not go past that screen, just let me know and i can tell you if you can and how you can, reinstall the update and or tell you how to get magellan to repair it for you for free.
the reset normally works 98% providing the files are not corrupt
bill
Feb 17, 2010 | Magellan Maestro 3200 GPS
It want turn on a
Battery is bad, try connecting to the car to see if it comes on.
Nov 16, 2009 | Magellan RoadMate 1220 GPS Receiver
My roadmate 800 will not turn on. When I use the reset switch, it goes to the blue "Logo" screen then nothing.
if its freezing on the magellan screen, there is a special utility from magellan to fix this issue. fortunately i havent had to use it yet so use caution while installing.
you can get the utility HERE
let me know if you need further help.
bill
Nov 14, 2009 | Magellan RoadMate 800 GPS Receiver
How do i change the language to spanish on my magellan roadmate 1200?
Maggie
Now, based on what you told me I understand that:
· You want feature information.
· You want to know how to change the system language
Maggie
RoadMate 1210, 1220, 1340, 1440, 1470
  1. From the main menu screen select the Settings icon (has a wrench and a screwdriver in an X formation)
  2. Select the option labeled "Sistema"(Spanish)/"Systeme"(French)
  3. Select the optino labeled "Lenguajes"Spanish)/"Langues"(French)
  4. Select your preferred language setting
  5. Confirm your selection by selecting the Back Arrow on the bottom left hand corner of the screen
  6. Unit will restart to make the language change
Jul 13, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Screen freezes
I did use the Premium live chat with you. I went through all the steps again that I already did on my own - i.e. resetting the pin hole with power on and power off...touching the screen in the corner when it was powering on....nothing changed.
I called Magellan. My warranty is still in effect and the Magellan rep gave me a repair number and address to send the unit. I will have it back and working in 7 to 10 days at no cost to me.
I wish it had been a really quick fix, I use my GPS in my business. I'm thankful for the warranty. I wish I knew why it did this so I can avoid any possible repeat of the malfunction.
Regards,
Judy in Arizona
Aug 23, 2008 | GPS
Gps loading screen freezes
If Magellan touch screen, try turning unit on while holding bottom right corner of touch screen. This will reset the unit.
Jun 27, 2008 | Magellan Maestro 4040 GPS Receiver
Screen Freezes
register your unit on the magellan website and there is a firmware update and it will solve your problem
Dec 18, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 1220 GPS Receiver Logo
1,370 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
