Defy - Gemini Cordon Bleu oven - won't switch on
Hi
Please help if you can. Our +- 10 year old Defy oven was working fine last night ...then suddenly switched off. The warmer still works, but anything to do with the oven will not come on.
I suspect the thermostat, but when opening it up could you best describe what the thermostat looks like?
Many thanks
  • thibathiba Oct 06, 2008
    The bottom oven does not light when swithed on. How should it operate it so as to be able to bake.
    Eunice
SOURCE: Old whirlpool washing machine won't run.
Press and hold the end of cycle signal button for about 5 seconds and it will reset
Posted on May 09, 2008
mikedurland
  • 481 Answers
SOURCE: Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Posted on Aug 04, 2008
  • 351 Answers
SOURCE: Asko W6761 Front Loader
check the fuse on the back panel if thats ok check to see where theres power it may be a display board fault.
Posted on Aug 27, 2008
IFIXALL
  • 868 Answers
SOURCE: Maytag Atlantis top-load washer won't fill with water, no power.
Not the lid switch>>>The water level switch ...unless you have forgot to turn the water on,Please Rate This !!!!
Posted on Dec 02, 2008
  • 4 Answers
SOURCE: maytag atlantis will agitate won't spin
I had the same problem with my Atlantis a couple of months ago. It turned out to be the bearing for the tub drive pulley. When you look under the washer there are three pulleys. The one for the motor is ont he left, the drain pulley on the right and the big one in the middle for the tub. What I found is that when the bearing went bad, the tub would fill and turn for washing, but it would not turn at all for spinning. I could turn the pulley by hand but the tub refused to budge. I removed the main pulley and could see that the bearing had exploded. You can't buy just the bearing but the whole pulley kit is like $35 so I got off easy. I put the machine back together (which is tricky) but it works fine now. The pulley kit comes with complete instructions but it's really straightforward. The tricky part is that you have to pull down on the end of the drive shaft in order to get the retainer ring onto the pulley. That can be difficult if you don't have a lot of room to work or have a partner to assist. You can replace the whole thing or just the bearing and save the pulley for a rainy day if you want. I opted for the whole replacement. But I saved the old. cause ya neva know!
Posted on Jan 16, 2009
Where is to cut out switch located in a gemini petite oven
if the oven is wired in to the house correctly
all ovens are hard wired into the house wiring
will be a trip switch marked" oven" on the house main power board outside ..
a fautly oven cant be used at all
call electrician for testing
ring for take out or home delivery meals
user manual link
OVEN DEFY GEMINI PETIT CHEF
https://www.defy.co.za/wp-content/uploads/.../Gemini-DBO472-DBO473-Manual.pdf
Oct 10, 2016 | Ovens
MY DEFY GEMINI CORDON BLEU OVEN IS HEATING UP TO EXTREME AND BURNING EVERYTHING I BAKE REGARDLESS OF THE TEMPERATURE SETTING
It may be operating on the broiler element, test the bake element for Ohm's resistance, and test the temperature probe too... Help Me Find My Model Number RepairClinic com
Jul 26, 2016 | Kitchen Ranges
Why would the bottom oven of a defy gemini cordon bleu oven stop working but the top oven is fine?
The igniter is bad if it's a gas oven or the thermostat won't turn on the igniter. You can check by turnung the oven on and looking at the burner. If there is no orange glow then the igniter needs replacement.
Aug 18, 2014 | Kitchen Ranges
Defy Gemini Cordon Bleu Oven
Hi, some ovens need to be reset with the timer to work manually. Set (turn) the timer (depending on the type of timer) till u hear a click (or pop of the button in a pushbutton timer). This worked for my non digital oven setting. Hope u are successful.
Apr 18, 2014 | Washing Machines
Bottom oven does not work tim eflashes and gives 0-.-7
Child lock is activated go to http://www.defy.co.za/images/manuals/OPERATING%20PROCEDURE%20FOR%20DEFY%20GEMINI%20%20OVEN%20%206%20BUTTON%20CLOCK-TIMER.pdf last page.
Apr 12, 2014 | Ovens
Free appliance manuals
Defy Gemini cordon bleu oven wont heat up because i fiddled with the timer
Jan 11, 2014 | Hardware & Accessories
I bought a house with a Defy Gemini Petite Chef oven but it is not working. The oven flicker on Auto. How can I delete the Auto?
Most models won't work when on Auto. There are push buttons under the clock and one has a picture of a hand (Like a cop holding up his hand to say "Stop"). From left to right numbering the buttons 1-6, this is button 4 on your appliance. Press this button and it should go back to manual mode and allow you to use the oven.
You can download a manual for this appliance from here:
http://www.google.co.uk/url?sa=t&source=web&cd=1&ved=0CBoQFjAA&url=http%3A%2F%2Fwww.defy.co.za%2FgetFile.asp%3FPath%3DD%3A%255Cinetpub%255Cwwwroot%255Cwww.defy.co.za%255Cimages%255CManuals%255C061_896_Gemini_Petit_Chef.pdf%26File%3D061_896_Gemini_Petit_Chef.pdf%26Size%3D342953%26Name%3D061_896_Gemini_Petit_Chef.pdf&rct=j&q=Gemini%20Petite%20Chef%20manual&ei=WfAWTqmnOsmYhQeotZHMBQ&usg=AFQjCNFC3Mdb5clrC_aHL8sq4P0zkfhmZA
Or google " Gemini Petite Chef manual " and the first hit has the link
Jul 08, 2011 | Ovens
OVEN NOT BROWNING CAKES
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
Washing Machines Logo
563 people viewed this question
Top Washing Machines Experts
