Question about Canon LaserClass LC 8500 Plain Paper Fax
Fax is blured on the right side - Canon LaserClass LC 8500 Plain Paper Fax
  • 385 Answers
It could be that the fuser film is faulty!It can also be the cartridge,i would suggest to try a new cartridge first if it is when u recieve faxes?Try putting in a old one to save u from buying a new one!If its still doing the same its the fuser film and you will have to replace it!Good Luck!
Posted on May 05, 2010
The fax received is coming blured hence how to fix the problem
please specify your fax machine model and brand first
Mar 05, 2011 | Office Equipment & Supplies
I'm having complants that my faxes are blured
Most common cause is going to be you need to have the scanner optics cleaned. Hopefully you have a local repair guy that can do this for you. However you can buy new basic fax machine like this now days for $75 to $80 which might be cheaper than servicing the old one.
Here is a tip for you tho. Make a copy using your fax machine. The quality of your copy is the same quality that you are sending out via the fax. So if your copy looks good then your outgoing faxes look fine. If you get a poor copy then that poor quality is what is being sent out. So copy quality = fax send quality.
Good Luck and Thank You for using Fixya.
Dec 01, 2010 | Sharp UX 108 Roll paper Thermal Fax
Solid black lines on the right side of page
Try sliding the blue tab on the drum unit side-to-side. If that does not cure it, you need a new DRUM UNIT
Oct 02, 2009 | Brother IntelliFAX 4100 Laser Fax
When I get or receive faxes, the right side is blurred.
If your getting blurred copies you may have moisture on your drum. Try cleaning it with alcohol(only) . If the problem persist replace drum.
Jun 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Left side and right side are blury.
With projection sets, there is typically several settings for which you can display an output. You probably have a "wide" or "stretch" as a setting for the tv. What you want is normal, or some setting which doesn't result in a stretch. Widescreen projection tv's try to stretch 4:3 output into the widescreen setting, but usually this just results in the middle being in focus, and the outer 20% to be stretched on each side, bluring the edges.
Try to manipulate as many "tv settings" as possible. For most sets this is only available with the original remote. If you don't have the original remote, changing these settings could prove difficult.
Apr 05, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Fax doesnt work right
Either a section of your l.e.d. array is dead (lights that light up under the sheet feeder when scanning), or the scanner glass under the sheet feeder is VERY dirty, but it's unlikely that it would be that contaminated. You can try cleaning it, but my money is on the LED's
Mar 31, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Fax problem
left side is printing and right is not printing.first clean thermal head after this check cover locks may bi right side cover lock is broken .just press from right side and make a copy .otherwise replace thermal head .MIAN AKHLAQ
Dec 18, 2008 | Panasonic KX-FP80 Plain Paper Thermal...
Fax machine does not print on the right side of paper
Probably the thermal head is bad. It's a spring loaded bar inside of the fax machine. You might be able to shim it closer to the paper on the bad side.
Oct 20, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
The left side of my pictures are blured.
If it's been like that since Day 1, I'd guess either an improperly assembled lens, or a misaligned CCD in the body. Hopefully it's a warranty fix. If it has recently started, it may be due to impact to lens or body. Fingers crossed for the warranty situation.
May 20, 2008 | Nikon COOLPIX S200 Digital Camera
Canaon is 860 Blured image. Always right hand side of picture.
Listen you need to take the camera back where you got it and tell the person at the store because it is the camera that needs to be fixed i had the same problem except with the bottom right hand corner of my camera.
Apr 01, 2008 | Canon IXUS 860 IS Digital Camera
Canon LaserClass LC 8500 Plain Paper Fax Logo
47 people viewed this question
old marine
old marine
