Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
Will not start up
Started computer as usual, turned on Acomadata 250 and nothing happens except constant blue light. Tried unplugging everything and re-booting, still nothing. Drive is hooked directly into computer
  • 153 Answers
Check it on other system
Posted on Apr 30, 2010
Constant alarm but works fine otherwise
Jordan,
It probably burned up one of the capacitors on the board that signal the UPS to turn the alarm off. I've had this happen before and I unplugged everything, turned the UPS off, disconnected the batteries and then opened the UPS up to cut off the tiny, annoying, surprisingly loud speaker. I then put everything back together and that was the end of it :)
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Feb 02, 2013 | Opti -UPS PowerES 1000 UPS System
I am running windows 7 on my dell computer. my acomdata external hard drive E5 has always communicated beautifully until today. when I click on my computer to communicate with the acom, there is no icon...
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jun 22, 2011 | Acomdata E5 (HD250FE572) 256 GB Hard Drive
Wont turn on, bios beep code
Seems heat-related motherboard POST failure. Replace it.
May 25, 2008 | Sony VAIO PCV-V210P PC Desktop
JVC HD-56G887 wont turn on
Your TVneeds to be serviced by a JVC authorized service center.
Mar 17, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Common problem...yet no working solution...
I think there's a capacitor that holds a charge for the blue-ring-of-death. The fix is to hold the menu button down for about 30 seconds (blue ring disappears) and continue holding for about 15 more seconds (or until re-boot). The additional time is required to discharge the capacitor.
If that fails, there is a safe-mode: place the device in hold, and press the mic and menu buttons at the same time. This usually doesn't apply to the blue-ring problem, but it may help.
Mar 11, 2008 | SanDisk Sansa e200 MP3 Player
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Monitor Display Problem.
Like most of these LCD monitors it is more than likely a PSU problem to do with the Electrolytic Capacitors, These in all probability will be faulty.. there are usually about 4 - 6 from 1000uF to 100uF replace ALL with same or better.
May 31, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
346 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
