Question about Dell PowerEdge 1800 Server
The server shutdown approxmatly every day
Every night at 9 PM the sever shutdown with an error in event log saying "The previous system shutdown at XXXXXXXX on XXXXXXX was unexpected"
  • raouf1234 Mar 25, 2008
    I hope to get a solution to this daily problem ASAP with my thanks .
    Problem Solver:
  • 17 Answers
If the log says that the shutdown was unexpected, then I'd suspect a power outage at that time. If you're using a managed PDU, check to see if that outlet (or the whole pdu) is set to power cycle. If you have more then one power supply, I'd recommend plugging them into different pdu circuits. If you're pluged in to a UPS, suspect that the UPS is cycling and that there's no UPS management service running. If you're plugged into (yikes) the wall, suspect building power.
Posted on Mar 28, 2008
Power is 2950 i912 sel full
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
Feb 04, 2014 | Dell PowerEdge Computers & Internet
Default system password
Upgrade log:
---------- HWK Update Client v 2.2.0.0 ----------
---------- HWK upgrade started:9/11/2013 2:41:46 PM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 72066
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-AFFA44634260001C
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Error: Server returned unrecognized reply
Sep 07, 2013 | Panasonic (KX-TDA200)
Need firmware update as stated in error message
You should be able to Update the Firmware from the IBM website:
http://www.ibm.com/us/en/
Good Luck!!!
Apr 23, 2013 | IBM xSeries 346 Server
Sel full 1912 error
You will get the "Sel Full 1912 error" on your server when the system event log is full and unable to record further events. You must clear the event log before the error will cancel. Boot your system into the BIOS/CMOS, locate the system logs and select clear log, reboot your system. Once the system is back up, I would go into the admin task folder and make sure the logs are clear there as well.
Good Luck.
Please rate my solutions here on FixYa.com
Jan 01, 2012 | Dell PowerEdge 2950 (becwfk1_6) Server
C2A2: system event log (sel) full
even tough you did not specify the generation of your server
if this is the complete error message
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS
this is the way to resolve it :
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key.
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup
Aug 18, 2010 | HP ProLiant ML110 Server
Server error
Clear System Event Log thru CMOS setup or the management software provided with server . The SEL is full that is the reason the error message
Mar 02, 2009 | HP ProLiant ML150 G3 Server
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
02A2: BMC System Event Log(SEL) Full
In HP prolliant server sets, setup also logs system events. This error is due to that log. Enter setup, trace log and clear all events.
Jan 28, 2009 | HP Compaq ProLiant ML110 G4 Server
Dell server poweredge 1800 frequently shutdown
is there an error message that appears? can you check error logs? I need more information to be able to help you. I would first try to blow dust out of the fans, as it may be over heating, another possibility is that there is software on the machine that is causing it to shut down.
Mar 17, 2008 | Dell PowerEdge 1800 Server
Zen Microphoto MTP drivers not installing, stuck in loop
Make sure you have media player 11
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
Download recovery tool off creative's website.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
Jan 12, 2008 | Creative Labs Zen Micro MP3 Player
Dell PowerEdge 1800 Server Logo
355 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
