Computers & Internet Logo
Posted on Apr 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why my sound card is not working - Computers & Internet
Anonymous
Level 3:
  • Master 1,481 Answers
  • Posted on Apr 30, 2010
Anonymous
Master
Level 3:
Answers
1481
Questions
0
Helped
312668
Points
4172
Some recent update from Microsoft has changed you IRQ of sound hardware chip in the motherboard.
no solution found till date....
but as an alternative you can try using the " USB sound adaptor"
buy in Ebay....
1helpful
Sound card stopped working
1st you disable the onboard sound card in BIOS level, then install/update the sound driver for Maddog Prowler 4.1 DSP soud card will solve your problem.
I have a Dell Dimension 4600, will a PCI Express sound card work in place of the original Sound Blaster 5.1 sound card
Well, the short answer to your question is "No, it won't work". The Dell Dimension 4600 does not have any PCI Express slots in it, therefore you can't install it, and therefore it won't work. But, if you installed a PCI sound card, it would work. The BIOS would recognize the add-on sound card, disable the onboard sound, and your sound will start going through the expansion card instead. Hope this helps.
1helpful
New Sound Card is not working.
Ted, the first thing you should do is go into your computer's BIOS and disable the built-in sound card. Once you do that, go back to your device manager and if the onboard sound card still appears there remove or disable it. Then reboot and your new sound card should be recognized and you can install drivers and begin using it.
Sound card problem
Does the Device Manager display this sound card, otherwise try adding hardware to and let it choose the driver automatically thru the net. Try cleaning the slot metal contact points with any clean paper, re-insert and try. If nothing works try any other sound card & if that works then most probably your sound card has got fried. Also if you are using Vista, not all sound cards are recognized by this OS and there is no way of installing a seperate driver...so all the best...........sodeep
Sound card are not working
try downloading new drivers for it if doesn't work i would say maybe your sound card took a dump it happens sometimes lala linda
Microphone and external bose speakers stopped working
it is not by sound card only ,check the sound utilities,driver ,and master volume control,
if all correct just remove the side panel (if u have PCI sound card or separate sound card) and remove the sound card and replug it,
if now not working u call to technition
regards
prasanna
[email protected]
Sound
the sound card is to be attached to the isa slot, if working should receive its resource and work, carefully attach the sound card to the isa slot, if working sound card it will be read if not it won't then put a working sound card.
UZOWUANYA
e-mail [email protected]
2answers
PCI card not been detected via Windows.
the sound card is installed into the ISA slot not the PCI slot.
clear the cmos for a minute, set it normal again.
install the sound card to the ISA slot carefully - i mean a working sound card and couple the system unit and boot, surely you will have your sound card working.
UZOWUANYA
e-mail:[email protected]
AC 97 Sound card turned off by code 10 error ?
A code 10 is so broadbased that Microsoft has this posted on its website. Please try the suggestions.
http://support.microsoft.com/kb/943104/
Grand Canyon Tech
Grand Canyon Tech
