Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Moved into house. Craftsman Garage Door Opener Model 139 18052 not working. Trolley won't move away from stop, chain loose, wires were not connected. Connected black to black port, red to red port, one white to white port, and twisted remaining 2 whites together to fit in last white port. No owners manual.
  • 504 Answers
YOU WILL NEED TO UNPLUG THE UNIT AND TAKE OFF THE COVER.
ROTATE THE MOTOR BY HAND UNTIL IT BACKS OFF FROM THE STOP - WHEN IT IS JAMMED NOTHING WILL WORK.
YOU SHOULD HAVE 2 WIRES WITH BLACK TRACE ON THEM 3 WHITE AND 1 RED TRACE.
YOU HAVE THE COLOR CODES RIGHT.
YOU CAN GO TO LIFTMASTER.COM AND DOWNLOAD A MANUAL FOR A SIMILAR UNIT - THEY MAKE THE CRAFTSMAN BUT USE A TOTALLY DIFFERENT MODEL # SYSTEM
HOPE THIS HELPS
Posted on May 26, 2010
1/2 horse garage door opener doesn,t open all the way. I need about a foot more lift. The tried a trolley stops before the stop limit..Therre is no interference. I Tried adjusting the up limit to no...
You said you adjusted the up limit already. Is it adjusted as far as possible? Usually the screw will become harder to turn. You mention a new door and spring but is the opener the same? My guess is you have a new opener as well and it is out of sync with the trolley. Try turning the up limit back and see if the trolley will stop shorter. If it does, loosen the chain or belt so that you can remove if from the opener's drive gear. Bring the trolley to your stop limit and put the chain/belt back on the gear. Adjust the chain/gear tension and try door operation again. If it was a sync problem, the door should close closer to your limit. Adjust up and down travel as necessary to fine tune it. This worked for me so good luck.
Sep 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman garage door opener (model 139.53637SRT - 1/2 HP) that stopped working. It sounds like the motor runs, but the chain and trolley do not move at all
The gears need to be replaced. You need
Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit available on amazon for around 20 bucks
Jan 16, 2011 | Sport & Outdoor - Others
When i press the key only the chains move leaving the door still up
Sounds like the trolley has been released from the door. Pull straight down on the release rope and let go. When the two halves of the trolley are lined up they should catch and the door will work.
Aug 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
I am having a problem with my garage door opener. It just clicks. Its a craftsman opener. The lights are on but it does not move when the button is pressed.
If your door is stuck in the open position it is probably because the trolley is jammed against the bolt just in front of the motor. If so, loosen the chain enough to release the pressure on the trolley and run the opener until the door is closed. With the door closed locate the 'up limit' control on the side of the motor unit and turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 1/2 hp garage door opener. Last night I had to open it using the emergency release due to power failure at house. Now it won't catch the door to open it although the chain mechanism...
That lever that the red handle pulls down is made to catch in the unlatched position. You can pull down on it again, and then pull the cord for and aft (parallel to the chain rail) and let it snap back up. Then either run the trolley or move the door and it will click back in.
Feb 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener 1/2 hp will not open door
It sounds like your chain is out of sync with the limit switches. Loosen the chain enough so that you can remove it from the sprocket on top of the motor unit. Now run the opener until the sprocket runs counterclockwise and stops. Now with everything attached and the door in the open position replace and tighten the chain. You are now in sync. You may need to tweak the up and down limit controls which are on the side of the motor unit.
Aug 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
How is the chain supposed to be aligned
sync the motor. the gear kit tells you how. get motor up and position trolley near motor, assuming you left chain/cable attached to trolley). Get motor up by running motor and then pushing button again. if motor reverse, let it run and it will stop in up position.
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener, chain adjustment
Loosen the inner nut on the trolley. (That is the lock nut). Then tighten the outer nut on the trolley to increase tension. The outer nut on the trolley is closest to the garage door. The chain tension should be 1/2 inch off the rail at midspan. (The chain is fastened to a threaded bolt on to the trolley. The threaded bolt has an inner and outer nut). Hope this helps.
Dec 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Opener will not reverse
FIRST YOU NEED TO RESET THE CHAIN .
Unplug power
Release the door from the opener close the door manually. take the chain loose and slide the traveler down to reengage with the trolley. Plug in power, run the unit with chain off untill it completes a clockwise cycle and stops. reconnect the chain and set tension.
Adjust the chain tension.
If it still moves 6-8 inches and flashes 5 times. the problem is in the rpm sensor.
Full diagnostics are in the owners manual - FREE at
http://help.chamberlain.com/help/en-us/InstructionManuals
Oct 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage opener/ brand garage master 1/3 HP
trolley is not attatced to the chain, grab that red rope that is hanging down and give it a ****. run the door up until it re-locks onto they trolley
Mar 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
126 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
