Question about MTX421D Car Audio Amplifier
Blowing speakers when i power the amp on with no rca's in place and hook a speaker up it pushes the cone of the speaker all the way out as it frys the speaker.
  • MTX Master
  • 5,603 Answers
The amp has a problem either with bad component(s) OR with the design.
The amp is driving DC out into the speaker and LIKELY one side of the final stage is shorted.
Be very careful in TRUSTING it after repair. I would put a fuse in the SPEAKER lines to save the speakers.
Posted on Apr 30, 2010
Testimonial: "thanks"
How do I hook up my subwoofer and amp to OnStar
i assume you want the sub and amp for listening to music and not the onstar itself, just the vehicle has onstar? if thats the case the easiest way would be to hook a line level converter into the rear speaker wires (both right and left) this gives you a RCA jack output to connest your rca cables to to send signal back to the amp. run power to the amp as described in the wiring kit directions and hook everything up as the amp requires. the rca cables would go to the "in" on the amp and you can adjust the line level converter for output voltage ( increasing the level increases the volume before the amp, so be easy on the adjustments or you could blow your speakers.)
Mar 24, 2011 | Car Audio & Video
My speaker stop workin and the amp is fine and everything is hooked up right
Looks like the speaker is blown , or the wiring inside the speaker is broken. To test if the speaker is working, simply hook up the terminals to the ends of a AA, AAA or C battery. Speaker should make a noise, and the cone should push outwards ( or pull inwards, if the polarity of the battery is reversed). Also test the wires that are hooked to the amplifier with a speaker that you know is good working order, just to make sure that there is nothing wrong on the wiring, on that particular channel in the amp.
Feb 03, 2010 | X-10 Memphis 15-PRC41 Power Reference 4" x...
I have a brand new soundstream xxx 6500d amplifier and when i installed it for the first time protect mode light come on even without rca jacks and speaker wires hooked up. any1 can help?
You need to plug in the RCA and speakers you could blow the amp. The amp is sensing no Input and No output. I would unplug the amp wait around 30 seconds then install the rca and speakers THEN install amp to battery + cable. You should be ok.
Jan 24, 2010 | Soundstream Xxx-6500d Power Amplifier Xxx...
When I hook up my kenwood kac-7201 the power light
leave power connections hooked up disconnect rca and speaker wires if they still blow more than likely problem with amp
Dec 31, 2009 | Kenwood KAC-7201 Car Audio Amplifier
One sub works other doesn't
Disconnect the wire from the speaker and meter it out. check it for a dead short, the meter would read 1..... You can also check the action of the sub by pushing on the center lightly, moving the cone. If it's blown, it will not travel smoothly. If your meter reads ......1 then you've really done it and totally cooked the wire clean thru, thus no resistance. Hope this helps.
Sep 29, 2009 | Xtant A3001 Car Audio Amplifier
I just bot Pioneer speaker CH26861...4 wires to 2 leads...
I would tie both + from the speakers to the radio, and both - as well. This will give an equal amount of power to both speakers and reduce the chance of blowing a speaker. As for +&- on the speakers, It is usually marked on the black piece right by the terminals. As little power as you are putting to the speakers, it doesn't really matter which way you hook them up, as long as they are both hooked up the same.
Jul 30, 2009 | Car Audio & Video
When i connect my power wire to battery my deck cuts off and when i disconnect cd player works
This is your receiver going into speaker protection mode. this could be one of a couple of things based on what you have stated. The obvious would be that your amp is pushing too much power for your speakers. You can try a couple of things. 1st is check your watts for your amp and speakers and adjust your gain accordingly(may need to adjust how much your putting out). If it is turning off with the gain turned all the way down, then that's not the problem. Try disconnecting the RCA cables, then hook up to the battery and see if your amp comes on. If it does, you have everything hooked up right for the most part. Doing this will make sure your getting power to your amp.
If you get power with the RCA jacks unplugged, you might make sure that whatever speakers are hooked up to the amp are disconnected from the factory wiring. Those are some things to check based on what you wrote.. Could you be a little more specific with things like what kind of speakers and deck you have, how many speakers you are running, describe what happens when everything cuts off, etc.
Jul 19, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Jl subs not powering
Connect each speaker coil one at a time to a square 9 volt battery and watch for the cone to move.
Also try hooking another speaker to your amp just to make sure it isn't in the amp.
You can use a 9 volt battery to test wire polarity also. Hook up the + wire of the speaker to the + terminal of the battery and the - speaker to the - battery terminal. If the speaker moved UP or OUT then the wiring is correct. If it moved IN or DOWN then the + and - wires are backwards on the speaker.
Also if you have two or more speakers hooked together test all the same way while they are hooked to each other. ALL of the speakers need to move in the same direction at the same time.
Clipping causes more speaker damage than anything. "Dirty Power" can happen in good quality amps too. The gain control is to match the voltage between the headunit and the amp. It is NOT a volume or boost knob. If you overdrive the first stage of the amp and then clip it damage will occur to the amp and speakers at some point.
Hope this helps.
Feb 22, 2007 | Jl Audio 12W3 Car Subwoofer
MTX421D Car Audio Amplifier Logo
43 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
