Question about Bissell LiftOff Revolution Pet Vac 37602 Vacuum
My steam cleaner wont pick up water i have checked everything and its fine but still isnt sucking up water
  • 20 Answers
Well Sexy mama ..are there any on~board screens that require clearing? Pet hair clogging up vac wand end? Is there vacuum power for attachment hose? Also, check that the wand /attachment switch is to vacuum and not set for attachments. Good luck !
Posted on Apr 30, 2010
Wont pick up anythimg
Check your pick up tube. Use a straitened wire hangar to push up tube and check blockage. You also may need to change the bag. Some bags sides will clog with fine dust and reduce the suction.
Jan 03, 2016 | Bissell Steam and Sweep Hard Floor Cleaner...
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac deep cleaner not ucking up
Hi! If your cleaner is not picking up this could mean that something is not sealed off properly. Try these brief trouble-shooting steps to restore suction to your SteamVac.
1. Remove the clean water tank.
2. Recline the handle and let the cleaner lay flat.
3. Remove the dirty water tank lid.
4. Reposition the front panel located on the outside of the tank in the center. It should be flush to the tank, even straight across and pushed down as far as it will go.
5. Assemble the dirty water tank lid back on from the front to the back. The lid should not lift up from the front.
Give it a try! The suction should be restored. Hope this helps!
Aug 26, 2014 | Hoover Vacuums
What cause it to stop sucking up the water?
has anyone answered.you or figured it out yet I just bought one and the suction wont work at all not from bottom or the attachment part heat works solutions works no suction at all help!!!please email me at taraamcgavran20@gmail.com
Jan 17, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell is not sucking up the water
Chech ut his link and this might help to solve your solutions. Hope this helps you.http://www.bissell.com/Search/FAQ.asp?FAQCategory_id=&FAQCriteria=water+wont+****&FAQSubCategory_id=&SearchMode=&SortMode=&btnSubmit.x=23&btnSubmit.y=9&FAQ_id=612
Aug 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell 2x steam cleaner is not picking up the water from the carpet. What do I need to do?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vxbv
Jul 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover steam cleaner F5912-900 not sucking up water
Check to make sure that the lid locked down all of the way around. If yours has a foam filter on the inside of the recovery tank lid, make sure it has at least a 1/4 in. gap from the top. There is a filter, from the bottom, has a red casing, remove it and clean it. Also make sure that the removeable duct in front of the recovery tank is in place.
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell 1699 ProHeat Clearview Steam Cleaner won't pick up
Usually if the water isn't being sucked up is either the filter in the lid of the tank is clogged, or the gasket that sits on top of the clear window nozzle and the tank is missing.
Jan 08, 2008 | Bissell 1699 ProHeat Clear View Upright...
Eureka deep steam cleaner
When these stop picking up water, I assume it is spraying the water out, is because of a missing seal, where the suction port is, or a filter is clogged. Tank isn't set down like it should be.
Jan 02, 2008 | Vacuums
Steam vac will not pick up dirty water
My Hoover Steamvac problem isn't with the bruches--it's with the suction. Dirty soapy water stays in the carpet instead of being returned to one of the holding tanks.
Oct 21, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Bissell LiftOff Revolution Pet Vac 37602 Vacuum Logo
159 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
