Question about Philips Profile BDP7310/F7 Player
Connecting dvd to tv
I have got a philips blueray dvd player BDP7300. No manual. Can i download one if not how do i connect to a 42in philips ambilight tv.
  • Philips Master
  • 5,161 Answers
Yes. The manual, a quick start guide and other documentation are available here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=BDP7310/F7&scy=us&slg=en
The DVD player has Component video out, AV Video out (RCA jacks - red and white for audio and yellow for video), and HDMI out. The Component video and AV video are close to each other; the HDMI jack is to the right on the back panel next to the LAN (RJ-45) jack. If needed, the manual for your TV may also be online.
I hope this helps.
Posted on Apr 30, 2010
    Scholar:
  • 103 Answers
Here, try this link. It is the complete users manual for the BDP7300. Good luck! -Der Strom
http://download.p4c.philips.com/files/b/bdp7300_05/bdp7300_05_dfu_ eng.pdf
My question is. . Is it possible to use a philips HTS3450 surround sound system without the blueray player?
Depends on how you intend to hook it up otherwise you will get no sound from the speakers if you delete the DVD player from the circuit. The speakers require a power source and this is provided via the DVD player.
You cannot connect those speakers up to an amplifier or an AV Receiver because the speaker connections are not compatible. The connections to the speaker wire where they plug into the DVD player would have to be changed because there needs to be a left and right wiring connection for each speaker.
So if I were you I would not mess with the system and just route everything via the DVD as it is designed to be done.
Dec 26, 2015 | Philips Audio Players & Recorders
Tip
DVD Player Quick Connect Tips
There has been a lot of confusion lately about how best to connect your new DVD or Blueray player to your TV set. For many this has been a nightmare since the introduction of the new Component and HDMI versions of Higher Priced DVD and Blueray disc players.
Remember that your new Blueray player will play DVD's as well as Blueray Disc format movies.
For the common connection that most people use, there are only 3 wires to consider. Yellow for Video, Red and White for Stereo. Always use the line out jacks on the back of the player to connect to the TV. Use the Line in (Video In) jacks on the TV set.
The only thing to remember here is to match the colors exactly and select the video source from your TV remote control. If all those numbers and buttons are confusing to you, just memorize where your Source button is on the remote, and choose one input at a time until your DVD welcome screen appears.
The next higher quality Video source will be the component Video outputs on your DVD or BlueRay player. These will be Red, Green And Blue.
Also note that you will need a red/white audio cable for sound with these connections since the component outputs only transmit Video.
You will be able to see the audio connectors close to the red blue and green component outputs on most players. All connectors on your player will be outputs, unless you bought a DVD recorder and player.
We will reference only the player type at this time.
As mentioned before, you only need to match the wires from the DVD or BlueRay output to the exact input connectors on your TV, but now the audio connectors need to be used as well.
Component to component cables/
Stereo Audio Cables/
Use your source selector on the remote as before to View your movie.
The easiest connector to hit the market so far is the HDMI version, which combines the Video signal as well as the audio signal into a single manageable cable. If your TV set doesn't have this connector you will need to use one of the above methods to connect your system.
To use the HDMI you need only plug it in to the connector designed for its use on both the TV as well as the player.
There is very little chance you will connect this to the wrong port, but just in case your HDMI TV and DVD/Blueray player are equipped with an Optional USB port, you should read the panel closely to be sure you have the right port. Remember, these connectors should never be forced on. If they are too tight to connect, you may have chosen the USB port by mistake.
Thats my Tip o the Day
Please Vote for this Tip if you found it helpful.
Bob S.
on Mar 23, 2010 | Audio Players & Recorders
How to connect netflix with sony blueray disc player?
Switch on the blueray player. Switch on your TV set. Connect your blueray player to the TV with an appropriate cable. Press HOME on the blueray player. Navigate with the blueray player remote control to NETFLIX and press OK. After a few seconds NETFLIX should start.
Jun 22, 2014 | Netflix
Does this model have the capability to handle a blueray dvd playe
Yes,u can hook up a normal DVD player in this tv before right?A Blu-Ray DVD player not much difference,just a better form of a DVD player.
May 22, 2010 | Televison & Video
Blueray screen shows "hello" "play" "dvd" and "setup." I cannot get a display screen or onscreen menu.
What cables did you use to connect the dvd player to the tv? If you used the composite, make sure the yellow is connected to the yellow.
Feb 11, 2010 | Panasonic DMP-BD605 Blu-Ray Player
When tv is wired to media center and then to blueray dvd , disc will not play. Non blueray disc will play. When tv wired directly to blueray player, blueray disc runs fine. Cables are hdmi
Hi.
When you say disk will not play I assume the BRD player does not start playing.
If the Blue ray unit does not start at all and stays in stand by , then the HDMI cable you are using to connect to TV, or HDMI port on TV may be defective.
Try replacing cable and swapping HDMI ports.
Oct 24, 2009 | Bose Audio Players & Recorders
Insignia tv ..can't get sony dvd to work
You most likely need to set the TV to the input source where the DVD player is connected (e.g. AV1, HDMI2, etc.) Without knowing the model number of your TV, I can't be more specific. Details on changing which input source you're viewing should be in your TV owner's manual.
Sep 19, 2009 | Sony DVP-NS55P DVD Player
Cable connections for dvd/vcr player, magnavox what are they.
A quick search in google reveals that you can download the manual from here:
http://www.user-manual-search.com/download.aspx?id=237&itemid=21233
When you click on the link it'll download the manual in pdf format automatically. It took me about a minute to download through broadband.
Hope this helps.
Feb 20, 2009 | Philips Magnavox 27MS343S 27" TV
Philips Profile BDP7310/F7 Player Logo
152 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
