Question about Kitchen Ranges
I think I vacuumed up a sock with my Electrolux central vacuum. Now there is hardly any suction. Will I burn up the motor if I let it run to try to get the sock to go on through? How do I fix this?
  • Kitchen Ranges Master
  • 5,603 Answers
Some of the cooling air might be lost so I would solve the problem before using it.
Consider using a shop vacuum to **** the thing backwards out the way it went in. You MAY need to temporarily remove the bag/container from the central unit while doing this.
Posted on Apr 30, 2010
Upon powering up suction is low. Needs to be primed with hand on hose intake; then full suction comes back.
Turn the vacuum on without the hose.If this continues the motor may need armature brushes or the motor itself may be burned out...motors are not too expensive,I usually put "Lamb" motors in for around 139.00....Chris
May 12, 2015 | Electrolux Central Vacuum
Burning smell
The motor is burnt out. Good news is that most central vacuums are really easy to get into so replacing the motor shouldn't be too hard. I haven't worked on that exact machine but the fault is unmistakable.
Jun 26, 2013 | Electrolux Central Vacuum
My central vaccum cleaner has no suction at all outlets even at the canister. The motor is still working and blowing air out the air release tube. What could be the problem
Check the filter in the tank. If this is dirty, the motor will still run, but there will be little to no suction. Rinse thoroughly under warm water, then allow to thoroughly air dry before replacing into vacuum.
I recommend having two filters in order to use one while the other is drying.
Jan 27, 2011 | Electrolux Central Vacuum
How do we get a sock out of the hose
Put the other end of the hose into the wall so that it reverses the suction if you can..
DO NOT STICK ANYTHING IN THE HOSE
If you can't reverse it you'll need to buy a new hose.
Jan 10, 2010 | Electrolux Central Vacuum
My electrolux central vac outlets work on the main
You might have a plug or clog in the upstairs lines. for information on how to remove a clog in a central vacuum system see this article:
http://centralvacproducts.blogspot.com/2009/01/how-to-unclog-central-vacuum-system.html
Oct 24, 2009 | Electrolux Central Vacuum
Filtex central vacuum
Check suction at main unit. If it is not good and the unit is empty you might need a new motor. If good there and one of the inlets is open, connect and disconnect the main line at the main unit. If it labors each time the line is connected, there is an obstruction in the line. If it doesn't labor you have a leak in your line.
Give me feed back.
Jun 26, 2009 | Electrolux Centralux Vacuum
No suction on my Electrolux central vacuum in all outlets even though motor is running and there is no clog in the hose.
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
May 05, 2009 | Electrolux Central Vacuum
Clogged hose
if you have a drain auger then you can stick it in until it won' go any further then you have hit the sock.turn the cable and grab the sock and pull it to the surface.please leave feedback
Mar 30, 2009 | Electrolux Central Vacuum
NO SUCTION
If you have no suction, there are only a couple of things that could cause it. As you have checked for blockage, and changed your filters, you may have a vacuum motor with bad bearings, or broken fan blades (inside/on the vacuum motor). Either symptom points towards a vacuum motor being bad and needing replaced.
Jan 21, 2009 | Electrolux Central Vacuum
Kitchen Ranges Logo
75 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
