Question about Sharp Microwave Ovens
MODEL R-1410A OVER RANGE MODEL- EXHAUST FAN RUNS CONTINUOUSLY - CAN'T CONTROL ON/OFF WITH SWITCH
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: exhaust fan runs continuously on Maytag microwave.
> MMV5165BAB hood vent fan runs continuously
You probably have either a shorted base thermostat on the base of the chassis of the oven or a shorted fan relay on the control circuit board.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
The base thermostat (which I believe has thinner pink and yellow wires attached, but not thicker black wires) should read normally open. If it shows continuity (virtually zero ohms or shorted) then it is bad.
Otherwise, I would say you have a shorted fan relay on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Jul 30, 2009
  • 574 Answers
SOURCE: Tappan over the range microwave - exhaust fan problems
most microwaves do not blow air out the bottom.They pull air from the bottom and blow it out the top.
Posted on Aug 31, 2009
SOURCE: JVM1530 When plug in microwave vent fan runs
beeping how to mute
Posted on Mar 04, 2010
The vent fan on my over the range Whirlpool microwave (mh1150xmq-0) runs any time I use the microwave (as if I have turned the vent fan on "low"). This doesn't seem to affect cooking, but it...
You either have a shorted exhaust fan thermostat or a shorted fan relay on the control circuit board.
While we regularly repair these controllers by mail for $39.95 postpaid with a one-year guarantee, or you can order a new control circuit board (part number) from the Pros here, we strongly suggest that you or someone you know check the exhaust fan thermostat first.
It should read "open" on a continuity (ohms) test. If it reads closed (shorted) it is bad and the fan will run all the time.
Or you can simply unplug the oven's power, disconnect one lead from the thermostat, tape it over to prevent shorting, then plug the oven back in. If the fan still comes on, the problem is on the board. If it does not, the thermostat is shorted.
Oct 14, 2011 | Whirlpool MH1150XMQ Microwave Oven
Lights under microwave went out. Replaced the bulbs and bulbs work fine, however, now the "surface light button" will not work. Pushing the button will not turn off the lights. Lights continuously stay on...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
Apr 26, 2010 | GE JVM1653 Microwave Oven
No lights or fan
If you mean that when you press Start and try to cook, the inside light and internal cooling fan are not working and it is not running, you may have trouble with a door switch or door switch mount. See this file.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If you mean the cooktop lights and internal cooling fan or hood vent exhaust fan are not working, we see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
Feel free to contact me directly with your brand, full model number and symptoms for free advice.
William E. Miller
prototech@usa.net
Jan 30, 2010 | GE Microwave Ovens
Whirlpool model number mh117oxsb-o Microwave shuts down after a few seconds,
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the turntable and stirrer won't work, and magnetron will soon be destroyed.
If not, then you probably have a bad door switch or door switch mount and should see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If so, then your magnetron may be failing or the cooling fan itself may be.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
If your under hood lamps recently went out, that surge could have damaged the control circuit board, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
here.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
Jan 15, 2010 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Model JVM1443 fan runs all the time when unit is
The top door switch (door sensing switch) is defective, or its mount is loose or broken.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you only need a switch, you can order a universal type here for $5 postpaid.
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Aug 31, 2009 | Frigidaire Over-the-Range Microwave
Exhaust fan runs continuously on Maytag microwave. Please help
prototech@usa.net
Jul 18, 2009 | Maytag MMV5165 Microwave Oven
GE Mircowave JES2251SJ -
The internal magnetron cooling fan is located behind the control panel assembly.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Nov 29, 2008 | GE JVM2050 Microwave Oven
Microwave Ovens Logo
142 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
