Question about Fellowes SB95C Cross-Cut Shredder
Paper is passing through shredder without being shredded
  • 61 Answers
Damaged bearings on the cutter shafts have allowed gaps between cutter shafts to prevent proper shredding, I think.
Posted on May 14, 2010
SOURCE: shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
Posted on May 21, 2007
  • 18 Answers
SOURCE: My shredder stop shredding. has paper caught in itposted
If your equipment makes abnormal noise when you try to switch on again then gear problem is confirmed else the change over switch should be defective or there may be a open circuit in the change over switch connection I shall advice you to call the service engineer for fixing the problem else take safty pecaution to attempt repairs
Posted on Sep 02, 2007
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Posted on Sep 08, 2007
fellowesrep
  • 102 Answers
SOURCE: shredded paper is wrapped around blades
Try saturating paper jam with liquid vegetable based cooking oil from your kitchen this should soften the paper after sitting 6-7 hours
Posted on Feb 23, 2008
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
How do you oil this shredder?
You did not give the model ## of your shredder. Most all shredders are OILED from the top slot where you you insert the paper to be shredded. DO NOT USE WD-40 OR ANY OTHER BRAND TYPE OIL. Use oil made for shredders or you can use SILCONE type oil. Wd Corp & Liquid Wrench companies make this type of oil. I have used it for more than 10 years in my shredder and I have not had a problem. The cutters work great.
Make sure BEFORE you oil that you make sure all shredded paper is removed from the cutters.
Spray from one side to the other(paper feeding slot) Run the shredder forward and backwards (WITHOUT PAPER) for about 5 seconds. This should be sufficient.
Sep 02, 2014 | Fellowes Office Equipment & Supplies
Why wont my staples titanium shredder continuously shred?
Not giving a model number, it's hard to say. But quite probably after use for 20 mins, the machine starts getting hot, and then it shuts down while the machine cools down.
I had the same issue with a shredder of mine. It prevents the machine burning itself out.
If you want one that just keeps going and going without heat issues, you have to pay more for a better shredder. Unfortunately.
Jul 30, 2014 | Industrial Paper Shredders Office...
Won t shut off
Blow out the sensors with some compressed air, Using a can of compressed air, look for the sensors that detect the paper and give them a blast or two, then try it, it may take a couple of tries.
This may also be a good time to lubricate the cutting heads, if it is a good machine with metal heads a light oil applied to paper then run through the shredder will pass the oil onto the heads.
A shredder oil or light oil like 3 in 1, these usually have a narrow nozzle to limit the oil flow, draw lines, do a picture or spell your name on the paper with oil and shred it. You have just serviced your shredder.
If it is a less expensive shredder with plastic heads, shredding a couple if sheets of waxed paper will pass the wax onto the cutting heads reducing friction.
Hope this helps.
Ed
Oct 01, 2013 | Office Equipment & Supplies
How do you remove the top to see the gears in a Royal 16CDX cross cut paper shredder. The overload message is displayed, and I don't know how to get it unjammed.
a possible solution is to UNPLUG the unit, reach in from underneath and start pulling stuck paper out. On mine (different model) I can remover the paper receptacle bin and reach up to remove stuck paper. this usually is caused by overloaded bin pushing shredded paper back up to cutters because it is overfull......BE SURE TO UNPLUG FIRST !!!!!
Nov 17, 2012 | Royal 160MX Also called 16CDX Cross-Cut...
Paper has wrapped around the cutting blades and is packed in tight. How do I clean this?
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
    • 3 Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Office Equipment & Supplies
Why is the fellowes blade still rotating even when there is no paper?
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
    • 3 Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
Sep 26, 2011 | Fellowes Intellishred PS-79Ci Shredder
My shredder overload light comes on immediately with only one sheet of paper inserted and it won't go.
Try running the machine in reverse and putting some shredder oil onto the cutting blades to loosen things up. Then try running the machine in the forward direction but hold the paper in the eyes but dont let it go into the shredding blades...see if it runs forward.!
If it will do this then slowly try paper 1 sheet at a time..but put some shredder oil onto the sheets of paper you are shredding.
If the overload light still comes on without even letting you shred 1 sheet of paper then you likely have another problem...maybe the motor or pcb..you can contact Royal at 1-800-524-0799 for parts assistance.
Oct 28, 2010 | Royal RS9512C Shredder
When you put paper in it starts to shred for about 1/4 inch then goes to reverse. No jams that I can see. Can run forward and reverse without paper with no problem. Sensor problem?
No mention of make or model however this holds true for all shredders.... especially if its a "cross-cut" shredder; put some shredder oil onto the cutting shafts where you insert the paper this will help get rid of some of the build-up that occurs due to the shredding process...also give the "eyes" in the middle of the "throat" a clan with a soft cloth( unplug the machine first or it will start to run and take your cloth in.) Occasionaly shrd a sheet of paper with some shredder oil poured directly onto the paper..this will help lubricate the cutting blades. Lastly...only shred up to about 70% of the rated cpacity..this will result in fewer jams an longer machine life.
Oct 19, 2010 | OfficeMax 0M96431 Shredder
Shreds in reverse only
I think there is a shredded buildup on the bottom. Unlpug the device ... turn it over and clear out the residue you will find there.
Sometimes I find the addition of shredder oil during the shredding process helps to eliminate this problem. Get the oil where shredders are sold.
May 31, 2010 | Tech Solution TS-4500 Shredder
How do I lubricate a Aurora AS702MX shredder?
two ways, first take a light oil (3 in 1) and scribble a pattern on a piece of paper and pass it through the cutting heads do this a couple of times, this can be done as you shred just put a little oil on papers you are about to shred from time to time.
second, if it is a light duty machine, with plastic parts, then pass some waxed paper through the shredder to clean and lube the heads, this also works for your 3 hole punches.
Apr 12, 2009 | Aurora Global AS702MX Shredder
Fellowes SB95C Cross-Cut Shredder Logo
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
