Question about Siemens WD61392GB Front Load Washer / Dryer
Siwamat 275 siemens
Hello I have a siwamat 275 siemens which I guess is old but still in very good condition and usually goes well. At the moment I swith it on and position the dials as usual. The red lights as normal but nothing happens. I have checked all the doors are closed and that water is available.
Normally a takes just a few seconds and the water valve solenoid kicks in and water pours in to the right level and then she off. Is there a timer in these machines that start thyings rolling ? I have a feeling that if so then this part is broken. I do not hear any mechanical noises at all. Can you help please. A circuit diagram would be nice or a bit of detail about the components would be appreciated. Thank you
SOURCE:
  • 13 Answers
SOURCE: Siemens Siwamat c12 manual needed
This site says they have the manual. I see it is not free, no idea how much they charge for manuals etc. Hope that will help you.
http://www.manualsnguides.com/search.php
Posted on Jul 17, 2009
SOURCE: Siemens Siwamat 2105 washing machine leaking
Ater beeing switched on the machine does not fill with water.
Posted on Jun 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: Using of Siemens Siwamat
press the start button after the door is closed.
if it does not start - the door switch/latch is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
SOURCE: hi there does the siemens
Yes - mine has just frozen in the garage and cracked whilst defrosting. Water everywhere. Does anyone know if I can bypass it and run the M/C on cold only?
Posted on Dec 29, 2010
  • 1527 Answers
SOURCE: I have a broken door
hello yes you should be able to try this site www.espares.co.uk or ebay hope it helps
regards
shaun
Posted on Mar 19, 2011
Siemens siwamat 9123 service manual
For a service manual, contact Siemens directly.
Oct 08, 2017 | Siemens Washing Machines
Siemens siwamat 6140
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTMUse the link, you will need to enter the Enr number which is on the rating plate and should start W...
Nov 22, 2011 | Siemens WDi1640 Front Load Washer / Dryer
I have a broken door catch for a Siemens Siwamat XB 1061. Can I get a replacement part
I feel for you because we have exactly the same problem : our door broke, the handle in fact. Everything else works wonder but the screw driver trick is bound to give in one day eventually and we'll be left with no washing machine at all. Has anyone found any infor on the door anywhere? thanks guys
Mar 19, 2011 | Siemens Washing Machines
Jul 17, 2009 | Siemens Washing Machines
SIWAMAT 6102 (GB) Code 3 Flashing. What does this error mean
The pump was working but not pumping. The rubber hose from the bottom of the drum to the pump was removed and found to be partially blocked. The debris inside the rubber hose was cleaned out and reassembled with no further problems.
Sep 07, 2008 | Siemens Washing Machines
Washing machine
f63 shoes on machine
siemens e 12 46 is the machine only 4 months old is there anything i can do befor i call an engnieree
Feb 23, 2008 | Siemens WFXD5200UC Front Load Washer
Siemens WD61392GB Front Load Washer / Dryer Logo
307 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Mike
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
