Question about Dacor DCM24 Convection/Microwave Oven
Hello my Dacor DCM24S microwave carousel won't spin
Hello my Dacor DCM24S convection microwave has a problem. The carousel will not turn. When I lift the black tray off of the wheeled trivet I see that the the turn disc in the middle of the microwave interior floor spins freely.
SOURCE: Dacor Microwave/Conv Oven DCM24S
elevate the popcorn by setting the bag on an inverted glass plate.
Posted on Apr 27, 2008
tiway1
  • 100 Answers
SOURCE: dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Posted on Dec 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven light stays on and turntable keeps turning
It would appear that relay # RY1 is stuck on your control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 20, 2009
  • 16 Answers
SOURCE: I have a Sharp Carousel convection microwave,
microwave's have fuses in them. try and replaceing them before you call the repair man.check on the web. for locations of fuses,hope this helps
Posted on Aug 05, 2009
  • 78 Answers
SOURCE: Dacor microwave model DCM24s broken door latches
Many times restaurant supply houses can have what you are looking for in terms of hinges. However, when the hinges, seals, megatron tubes go....generally its time to go shopping for a new unit!
Posted on Nov 09, 2009
Dacor Microwave DCM24S cooling fan continues to run
follow this steps and fix it. God bless you
  1. Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#9#ixzz2aNH65mG4
Jul 27, 2013 | Dacor DCM24SS Convection Microwave Oven
Dacor DCM24S microwave not working--not heating and table not rotating
The bottom door switch or its mount is bad.
See the service manual here and a help file on door switches here.
Nov 23, 2012 | Dacor Microwave Ovens
My DACOR microwaive/conviction oven (model no. DCM24S) suddenly went dead. all of the lights are off and it does not work. I checked the circut breaker I found it to operate properly. could you tell me wha...
We have the service / repair manual and parts list for this model and have uploaded them to our site here and here for free download to help you.
You can find Dacor parts by entering the part numbers at the Pros' Web site.
Oct 16, 2011 | Dacor DCM24 Convection/Microwave Oven
Can I get an electrical schematic for the Dacor DCM24S. Thank you. AE.
We have the full service manual for this model and have uploaded it for you here.
You can order parts (by part number only) from the Pros here.
Let us know if we can help further.
We're
Jan 15, 2011 | Dacor DCM24 Convection/Microwave Oven
Nov 09, 2009 | Dacor DCM24SS Convection Microwave Oven
Dacor DCM24 Door is out of alignment
Loosen 3 screws on lower hinge, lift the door to realign, then re-tighten screws.
Jan 29, 2009 | Dacor DCM24 Convection/Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Dacor Microwave dcm24s
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 14, 2008 | Dacor DCM24SS Convection Microwave Oven
Dacor DCM24 Convection/Microwave Oven Logo
101 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
