Question about iRiver H10 MP3 Player
H10 20GB battery.
Battery does strange things like it is now down to 50min playing time. It revives but only does the same thing again. Is it possible to get and fit anew battery yourself?
    Problem Solver:
  • 12 Answers
Battery problems always consist of the conditions of where it's being put. Try to keep all your electrical belongings in a cool temperature, mainly around 65 to 70 degrease C. You need to contact the brand provider and make sure you have a warranty on this product, just in case any other problems occur.
don't panic!
bananaboy101
Posted on Mar 25, 2008
Gateway 6920
The dying hdd cause some problems. Replace the hdd.
Feb 21, 2014 | Computers & Internet
Tail lights and dash board is not working
if its just the cluster flashing chanses are it needs to be sent out for repair but try diconecting the battery for a bit then reconect it and see if any thing changes also check and see if teh battery is good low voltage can cause strange things to hapen
Feb 11, 2014 | 2007 Chrysler Sebring 2.4
2008 CX-9 when I shut off the engine, the heater/AC Fan keeps running. It seems that when i change the battery in my remote entry thing, the problem goes away for a while, but return days or weeks later. ...
Common issue. Replace two relays (one for front, one for rear) in the fusebox in the engine compartment and guarantee the blower will turn off properly.
Dec 02, 2010 | Mazda CX-9 Cars & Trucks
1999 Nissan Altima problem... Today my car had a strange scent. Possibly rubber burning. The next thing my car started sputtering and cutting out. When I pulled off the road, It would not start but seemed...
This could be any number of things, check all of your belts and make sure they are there. Do a visual inspection of the wires under the hood and make sure none look burned. The last thing to check would be the timing belt on the car under the cover behind the rest of the belts. If this has stripped the car could have jumped time and will not let the car run and could cause more damage the more you try to run it.
Sep 11, 2009 | 1999 Nissan Altima
Dead battery I want to 'recycle'
This option is worth a shot:
http://sodoityourself.com/reviving-laptop-batteries/
There is also the cheaper alternative third-party sellers:
http://www.global-laptop-batteries.com/dell-laptop-batteries.html
Generally speaking, Li-ion batteries should not be frozen. Putting the battery in a cool place will help a little, in that while the battery is cold its 'aging' will slow. It will start to lose capacity permanently at a normal rate when it warms up again.
I hope some of this information has helped. If it has please rate, if not please let us know.
Mar 29, 2009 | Dell Latitude D620 Notebook
'92 probe won't hold charge
cold does strange things.. check battery health with load test... check cables especially grounds... test for parasitic leak of electrical by inserting a test light between battery ground post and cable .. only faint light for radio and comuter should exist ..a bright light means a draw and should be discovered by removing fuses one at a time til located ...good luck
Jan 14, 2009 | 1992 Ford Probe
My vehicle dies everytime I turn it off...
how old is your battery,have you tried a new one?Sometimes a really stuffed battery also interferes with the ECU,and can result in switching things on and off.
Dec 15, 2008 | 1994 Mercury Grand Marquis
WILL NOT TURN ON
Possible solution.  So, my sansa express went dead after pluggin it in to my computer after a few weeks of use.  It was totally dead and unresponsive.  Didn't turn on at all.  Plugging it in wouldn't effect it and windows only recognized a malfunctioning usb adapter.  Thus, reprogramming the firmware was out of the question.
Solution: the soft reset actually worked.  You have to soft reset (hold down the grey center button and the volume up + key at the same time for a few seconds.)  Then plug it into the computer.  Voi La.  It came back to life.  The strange part was that it still wouldn't turn on after the soft reset.  It required me plugging it into my computer to revive the thing.
Dec 03, 2007 | SanDisk Sansa MP3 Player
Battery charge
Put 2 batteries in flashlight and ran completely dead. Charged them in 1hr. 50min. Pulled plug per directions for first time charge and plugged back in. Light went out in about 10 - 15 min. Plugged in third time with same results. Is this normal. Haven't tried them in camera yet.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
iRiver H10 MP3 Player Logo
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
