Question about Samsung HZ10W / WB500 Digital Camera
Hi,my name is terence harvey.i bought a samsung wb500 three months ago.the telescopic lens is stuck.any idea's
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 30, 2010
Testimonial: "thank you very very much my camera is now working perfectly;what ever was causing the problem removed it's zelf at fix 6.Brut force and ignorance "
My wb500 wont swich on but as full battery
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
May 09, 2011 | Samsung Cameras
HEY ! my Samsung WB500 won't turn on...I've just bought it, well it was a present but its brand new AND i've charged it and everything, but it won't turn. need help ASAP.
I just had the same problem. All I did to solve it was take the battery out, scratch the contact on the battery (CAREFULLY) and put the battery back in and now it works. The contacts must have oxadised a little. This is not good as far as quality is concerned but it was an easy fix.
Hope this helps!
PS I love my WB500!!!
Nov 27, 2010 | Samsung HZ10W / WB500 Digital Camera
I cannot upload photos from my wb500 samsung camera and would like some help on how to do this
Having gone over a month without a response, I assume my suggestion solved the problem.
Jul 09, 2010 | Samsung HZ10W / WB500 Digital Camera
No remote control
call samsung customer service listed in your manual
Oct 25, 2009 | Samsung HZ10W / WB500 Digital Camera
Headache
Since you purchased it fairly recently it is probably still under warranty. Contact Samsung. Camera instruction book probably has contact information or try their website.
Jun 11, 2009 | Kodak EasyShare M853 Digital Camera
I have a canon powershot tx1 and i just got a 'lens error, restart camera' message and my lens is stuck. i just bought it a month ago and haven't mistreated it at all. how can i fix it?
I have a canon powershot a470nd i just got a 'lens error, restart camera' message and my lens is stuck. i just bought it a month ago and haven't mistreated it at all. how can i fix it?
Jul 24, 2008 | Canon Cameras
Hi my name is amit sharma currently residing in melbourne. i purchased samsung plasma "50" inches. i purchased it 3 months ago.i had to borrow money to do this. when i bought this plasma i was...
Look in your owners manual and contact Samsung and complain about the Repairs. They can't do anything about the promotion deal, but they should check into the repair issue for you. Especially if the Company servicing the TV is an Authorised Samsung Center.
Hope that helps...
Geno
Apr 04, 2008 | Televison & Video
Camera frozen
The autofocus motor is stuck. It's a Samsung common problem and can't be fixed by the user. If it's still under warrenty you can send it to the the listed repair facility in NYC, otherwise you might wind up paying aa much as what you bought if for. BTW, they fixed mine while it was still under warrenty and three months later, it's broken again with the same problem. My advice? DON'T BUY ANOTHER SAMSUNG PRODUCT AS LONG AS YOU LIVE!!
Dec 21, 2007 | Samsung Digimax S500 Digital Camera
Samsung nv10
I too have this problem. I sold the broken one on ebay, and bought a second hand one and low behold - it TOO has a stuck lens.
unfortunately warrentey ran out months ago. How depressing.
Dec 14, 2007 | Cameras
Samsung HZ10W / WB500 Digital Camera Logo
518 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
