Question about Hayward H-series Electronic Gas Pool Heater H400
Hi what size and kind of regulator do i need for my hayward propane H250 pool heater i have 2 100 lbs tanks
  • 990 Answers
This is something your gas company should figure and supply for libality reasons. they will be responseable for any damage done from improper pressure. They will need to figure along with heater size and tank size, pipe size and run of pipe along with other varebeles like number and type of fittings on line and other appliences on the feed.
Posted on May 01, 2010
What does lo mean on my h250 hayward pool heater
LO standss for limit open. the most common cause is lack of adequate water flow through heater. other causes are high temp limits.
Jun 10, 2014 | Hayward H Series Pool & Spa Heater 400k...
Hayward H250 has LO listed on the electronic panel after it had been blowing black soot out of it
check gas pressure heater overheated probably needs hi limits or fusible link plus clean heat exchange to solve
Oct 12, 2012 | Hayward H-series Electronic Gas Pool...
Pf hayward error code on gas heater H250 IDPL1
check pressure switch if voltage both sides ok if not bad switch or clogged copper tube also check filters
Nov 16, 2011 | Hayward H-series Electronic Gas Pool...
What type of regulator do i need to connect my propane tank to the heater?
You need a regulator rated for the heater. Your propane dealer can provide you with exactly the right regulator.
May 24, 2010 | Hayward 100k Btu Propane Gas Pool Heater...
What size regulator do i use with h100 propane pool heater???
Their are many varibales that go into this and your gas company should be able to help you with this. They will quite often send someone out to check for you as they get to sell you more gas if you run the heater. But you need tank size, pipe size, run of pipe, local weather to name some of the things along with all other appliences in the house. So you do need to have it sized by a pro on the job site.
May 12, 2010 | Hayward H-series Electronic Gas Pool...
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
HEATER WAS WORKING FINE TILL I HAD PROPANE TANK TOPPED OFF
The Pressure Regulator may be stuck, Try closing the propane valve releasing the pressure,, gently tap the regulator( on the propane inlet side) and Very Very slowly open the propane tank valve, and attempt to light
Jul 30, 2009 | Hayward H Series
Hayward Pool Heater is not working. Fan turns on, but that is it.
I had the exact same problem. The propane guy had to come back and put the regulator right by the heater instead of being on the tanks. Did this and boom heat. This was after 6 days of calling and calling hayward tech and service guy. Hopefully it will continue to work :/
Jun 07, 2009 | Hayward H Series Pool & Spa Heater 400k...
Trouble shooting Hayward pool furnace
Big enough propane tank? proper pressure reducing valve on the propane? Check both of those.
May 30, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward h250, wont heat
Sounds like it could be the flame sensor.
Apr 04, 2009 | Hayward H Series Electronic Ignition...
Hayward H-series Electronic Gas Pool Heater H400 Logo
410 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
