Question about Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump
My sta rite pool pump turbine is turning slowly and i think i need to clean out debris from the turbine, how do i do this ?
  • 990 Answers
With the power off, you can remove the basket and reach inside the hole behind it into the pump body. Use a screwdriver and needlenose plier to do this. If you can feel the clog. (It will be soft and spongy) work it counter clockwise to loosten it from the impeller. Then pull it out with the plier. Hope this helps, good luck.
Posted on May 01, 2010
BHR170 hose set up
in form skimmers out to filter in to out of filter to returns
Jun 01, 2014 | Sta Rite Sta - Rite 24" Sand Filter & 1 Hp...
We accidently left our Sta-rite pool pump on when we went out of town for 4 days. It ran dry during this time. Now when we turn the pump on, water shoots out of the top under the handle and makes sounds...
sounds like the heat from the pump melted the seals in your multiport replace multiport and pump you should be ok you will need to replace some of the pvc pipes they expand when heated you wont be able to put fittings on them
Sep 07, 2013 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Sta rite pump
no bearings available need new motor
May 01, 2013 | Hayward 1 Hp 2 Speed Super Pump Inground...
Pump still runs but no presure coming out of jets
Check your impeller. I think you have (1) spun the center out of it or (2) you are clogged with debris.
Aug 02, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Looking for manual on Sta Rite Sand filter Model HRP830
Here is a copy of the users manual for Sta Rite BRPB30 pool filters.
http://www.pool-filters.com/pdf/Sta-Rite-HRPB-Filter-Manual.pdf
Apr 16, 2011 | Sta Rite Sta - Rite 31" Sand Filter & 1.5...
Cleaning appellants
do what? I THINK YOU MEAN IMPELLER ? THIS LINK WILL HELP YA UNDERSTAND YOUR PUMP BETTER PUMP HOW 2 YOU WILL NEED TO TAKE OFF THE DIFFUSER AND WITH A STIFF PIECE OF WIRE, LIKE A CLOTHES HANGER. YOU CAN PUSH THE TRASH TO THE CENTER OF THE DIFF. THESE STA RITE PUMPS ARE THE BEST PUMP... YOU MIGHT NEED A NEW HAIR BASKET .. IF I WAS OF ANY HELP.. LEAVE ME SOME FEEDBACK.. OH AND PRIME THE PUMP AFTER ANY PUMP REPAIR !!!! Jay .. free puppy bight CLICK HERE
Jan 30, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Help low pressure in pool pump and filter
I can relate so well to your problem. My pool is surrounded by pines and deodora trees... all the needles seem to find their way through the baskets, strainers and into the inlet of the pump. It became a daily routine of having to reach into the inlet and clean the debris if I wanted a filtered pool.
Here' s a solution that will work!
Purchase an extra debris scoop ...the kind you put on the pole and scoop debris from the bottom of the pool.
Cut the net out of the frame and wrap the netting around the skimmer's debris basket and secure it with an oversized rubber band or zip ties, then replace the basket back in the skimmer.
Your skimmer will keep the debris out of the pump!
This will make a world of difference in your pump's pressure!
Give it a try and see if you're not working better!
Jun 03, 2010 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
Sta-Rite Dyna Glas Pool Pump
debris may have gotten into pump or pump is air bound need to check pump first try to bleed pump if water comes out and not pumping hard possible burnt up impeller or seal
Apr 03, 2010 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Sta-rite problem
Pump is heating up and kicking the breaker try cleaning the pump filter and let me know by posting to this solution.
Sep 29, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump Logo
88 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
