Question about Garden
Poulan pro lawn mower starts & dies
Poulan pro lwn mower starts, runs for a little while and dies. Could this be the condenser or points? I've flushed the gas, put in new plug, & cleaned filter. Where is condenser located?
  • 61 Answers
Unless this mower is older then i am, it has no points or condenser. It has only a magnito. Sounds more like a plugged up carberator.
Posted on May 09, 2010
  • sunneyskies May 16, 2010
    If this mower has a briggs & stratton engine, try this. On the bottom of the carberator bowl, there is a half inch nut. Unscrew this nut. Now take a close look at this nut. You will find near the bottom of it a hold that goes stright thur it, and also you will find a hole in the center of it going from top to bottom. This nut is really, the main jet of the carberator. Use a fine wire and be sure all 3 of these holes are open and clean. If these holes are plugged, you should take carberator off and take it apart and clean everything. If the main jet is plugged, chances are, the whole carb is.
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
Gap setting for condenser
there is no gap setting for a condenser only the points. Try .012 in. to .015 in
Jan 04, 2013 | Poulan Pro 22" Self Propelled High Wheel...
I evidently put too much oil in the Proulan Pro Lawn Mower. Now I cannot get it started. It sputters at first but will not start. I have cleaned off the spark plug with a paper towel and sand papered the...
First thing is to remove the excess oil. Take out as much as you need to to get to the line on the dipstick. Next, you may want to use a little WD-40 or similar cleaner to spray into the spark plug hole to thin the oil in there. Replace the spark plug and start the machine a number of times until it runs correctly. Using WD-40, remember the term "little". Good luck...Lee
Jul 22, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Mower runs fine till it's in the grass, it dies instantly
too much oil too little oil.............check the blade some thing maybe raped around it
Oct 03, 2009 | Poulan Pro " Pro" Self Propelled Mower
Claen carb an still will not start?
Spray some carb cleaner into carb and try again. If it starts for a little while and then dies, you have spark and your carb is still your problem. If this is the problem clean every little hole using carb cleaner and needle(sewing needle that is). Make sure the carb cleaner comes out of some other hole than the one you are spraying into for each. Sometimes you need to keep the engine running with the carb cleaner for a while(1-2 minutes) by shooting short spurts into the carb just before it dies.
Jun 03, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan Pro mower starter engages but plugs don't have any fire.
No points and condenser. Brigg and Stratton hasn't had points and condensers since 1981. Dwain
May 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Starts, runs, and dies...starts, runs and dies...starts, runs, an
Sounds like a common fuel problem you need to remove carb & fuel tank and unless you can get a compressor they need a good blast out you may even take carb apart & check diaghram they have very small jets in fact most lawnmower shops have a sonic bath for this
Apr 25, 2009 | Poulan Pro " Pro" Self Propelled Mower
Garden Logo
515 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
