Question about Brother IntelliFAX 2800 Laser Fax
I have a brother intellifax 4750. When I try and copy or send a fax, it has a big black line through the received page.
  • 7 more comments
  • andy_emilio Apr 30, 2010
    My received faxes are fine, it's the one's I send!!
    Also, what is the difference between a drum unit and a toner cartridge??
    No help, there is a 3/4" thick black line all the way through the received fax at the other end. Have you heard of this before? Again, when I receive a fax, there is no line so I dont think its the cartridge or drum. It has to do with what the machine is seeing to copy or send.
    Okay, sorry to bug you but I cleaned the chrge wire so I guess it's the glass. Lifted the panel (it only swings up a bit) and cannot see any glass/mirror. Is it the bigger part that is screwed in?
    That's correct. The person receiving my fax has a thick black line down the left side. When I receive a fax, no line.
    Again, yes, it is the receiver getting the black line.
    I dont see any glass when I lift the dial panel, just rollers etc.
    Everybody I send to. It is coming from my machine.
    As I said before, I don't know how to find the glass.
  • andy_emilio May 02, 2010
    Thanks for your patience. Great help.
    President:
  • 3,278 Answers
Hello, Andy.
Sounds like the toner cartridge needs to be changed.
Hope this helps.
Posted on Apr 30, 2010
  • 7 more comments
  • NinaE Apr 30, 2010
    Hello, again.
    Regarding your question of toner vs drum, the toner cartridge is just a cartridge that contains toner. The drum does the
    work.
    Make sure you clean the charge wire which is located within the drum and toner
    unit. Sometimes if the charge wire is dirty, it would cause that problem you are experiencing. Also,
    check the mirrors if they are clean. Open the top cover, remove the glass and you will see the mirror.
    Hope this helps.
    Yes ... a dirty charge wire or dirty mirror is usually the cause ...
    So, that line occurs for any sent FAX, not just a certain FAX and the receiver gets a black line from your FAX and not from any other ?
    The receiver gets a black line from your FAX only -not from any other ? When you send a FAX to a different FAX line, does the receiver get a black line ?
    You have to remove the glass to see the mirror.
    If the receiver is getting the black line, there could be a problem with the receiver's FAX machine. Unless, as I tried to convey, the receiver is getting other FAXes that are OK.
    Another thought ... your scanner may be dirty - clean the glass with Windex.
  • NinaE May 01, 2010
    Hello, Andy.
    From Brother:
    Cleaning the Document Scanner
    1 Unplug the telephone line and then the power cord.
    When you reconnect these lines later, connect the power cord first, then the telephone line.
    2 Lift the control panel cover.
    3 Clean the white bar and glass cover under the white bar.
    Moisten a small, clean, soft,lint-free cloth with isopropyl alcohol and carefully remove dirt
    from the glass cover and the white bar.
  • NinaE May 02, 2010
    Glad to help. Thanks for using FixYa.
Black copies
It appears that you have a bad SCANNER BLOCK
Sep 30, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
People receiving fax are getting black pages, all locations I send fax to.
If you make a copy on the fax machine, is it all black too? Yes? Most likely the scanner bulb (under the auto feeder) is blown out
Jun 12, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
BLACK LINE 1" THICK ON FAX COPY BEING SENT OUT
I bet your incoming pages are clean right? The Laser is not used for outgoing faxes.
Lift up your document feeder and clean the scanner glass that the documents are scanned across
Feb 24, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother 4750e fax machine
1- check the small stip of glass and see if it has toner,
check the maintenance section of the manual (it's free, just register)
http://www.retrevo.com/support/Brother-4750-Fax-Machines-manual/id/19095ci557/t/2/
Aug 04, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother intellifax 4750e
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
When we copy on our 4750e fax it comes out with black page
Can you see light from the scanner unit with you make a copy or try to send out faxes? The bulb for the scanner may be burnt. You might be able to find a replacement bulb, search google or contact Brother.
Jun 16, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFAX 2800 Laser Fax Logo
43 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
