I have a Beko L.C.D. T/V Model NR32WLZ530HID With an Intermittant picture. With the back removed, I notice all Backlights Cycle On/Off at approx 1 second Intervals, when its on Picture and sound are O.K. Can You help Please. Many Thanks tvted.
  • 1 more comment
  • Edward Jones May 01, 2010
    Many thanks to;- rylee smith for stating the obvious, but, i would like another Expert to check if there is any known history of this fault, if not,please have you any helpfull suggestions.
    Many thanks
    tvted
  • Edward Jones May 03, 2010
    I have checked Caps, and dry joints All O.K.
  • Edward Jones May 04, 2010
    I accept this solution, and go in search of a new inverter board.
    Many Thanks
    tvted67
  • 4,889 Answers
The problem you have mentioned indicates a backlight inverter board failure. Not a very difficult problem to fix and not expensive either. You can get a replacement board for about 30-50$. Only problem is finding the replacement. If you can get me the part number we can solve that too.
Posted on May 03, 2010
  • 5,138 Answers
Do you see any capacitors that are swollen,vented or puffed up on Top ? If you do they are bad. 1000uf 16v, 220uf 10v, 3300uf 10v
Also Look for poor solder connection.For Parts/supplies Go to Encompass Parts Distribution and type in your Model number.
Posted on May 01, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight and/or an inverter board issue with this TV set. It could also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire inverter board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. The cost to change the inverter board including labor would be around $250, if you get this done by a professional. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 30, 2010
The LED back lights will not stay on. I have sound and I can see an image with a flashlight.
inverter board is most likely the culprit since it feeds power to the backlights.
Jun 08, 2016 | LG Televison & Video
Hi I have a beko fridge freezer model ACD653FW/1. ALL I want to know is where is the control board located.
not finding anything on the model number you posted - check it please.
the beko put the boards in a variety of places
on the bottom - underneathe the fridge - have to lay it on the side or back to get to it if it's there.
on the back - behind a removable panel midway down from top
have even seen them in the door
Jan 04, 2015 | Beko Refrigerators
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 28, 2014 | Beko Washing Machines
I have a beko wm5120 s which will not start any cycle, i noticed that the door lock in not locking can anybody help , please Regards Graham"
I think a glitch here caused this to be listed in the TV areas and it sounds like a washing machine?
Dec 13, 2012 | Beko 142746 TV
When i turn on my tv the picture is fine then it goes darker and it stays darker
First things is check the picture adjustment.Try to adjust the brightness and contrast.If did not work the problem is the backlights of the LCD. Usually in that case the problem is loose connection in the backlights connector. The backlights have high voltage so it may cause of overheat at the connector.So try to check the connection of the backlights at the board of your television.Remove the back cover of the TV and look the conector of the backlights and try to resolder and fix it. Thanks!!!!
Aug 21, 2011 | LG Televison & Video
Beko WMA765S fills, stops, then drains and stops
i would think about replaceing the timer
Sep 09, 2009 | Washing Machines
Blank screen beko lcd 26" lcd tv - sound ok (model no. L5A)
While you have sound, take a flashlight and shine it on the screen, look very close and see if you can see a dark video image.
Let me know what you see.
lone99star
Jan 08, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 | Freezers
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
