Question about Corel AE CorelDRAW Graphics Suite 12 for PC
Uninstallation I tried to install corel draw 12 from a cd, but due some fault the intallation couldn't complete. Then, I removed it from the add\remove program. But its, installation process window pops out every time I right-click on the desktop to go to 'new' option in the menu. Please tell what should I do to remove it.
    President:
  • 1,944 Answers
Use CCLEANER to get rid of it.
www.ccleaner.com
Posted on Mar 25, 2008
Corel DRAW X6 problems
I presume you mean CorelDRAW Graphics Suite X6 and NOT technical Suite?
If nothing seems to work I would then do as follows.
1.Uninstall CorelDRAW X6 via Control Panel
2.After uninstalling X6 in the Control Panel - Go BACK to the Control Panel and uninstall "Corel Graphics - Windows Shell Extension".
3.Then go to Documents > Corel folder > Uninstall/Delete anything that says CorelDRAW X6
4.You can also go to C: > Program > Corel and delete anythign that says CorelDRAW X6
5.Repeat step 4, but choose folder called Programx86, and delete anything that says CorelDRAW X6
6.You should now have uninstalled everything that useally could disturb when you re-install from scratch.
7.NOW put in your DVD again with CorelDRAW Graphics Suite X6 - and INSTALL from Scratch.
8.You SHOULD now be able to run your CorelDRAW X6.
9.And NOW you should go online to www.corel.com and download and install Update/service pack and Hotfix for CorelADRAW Graphics Suite X6
10.It should in all normal situations work just fine on your PC with any Windows 7 version as well as any Windows 8 and 8.1 version.
11.Try to use a program to recover and view CDR files. For example, you can try this CDR Open File Tool http://www.cdr.openfiletool.com/
12.Also recommend to come to this forum. Many have useful information on the topic. http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/479-problems-with-cdr-files
Good luck and hope this helps!
Nov 12, 2014 | Corel DRAW Graphics Suite X5
Lost serial number
download u torrent software install and search in Google (corel draw x3 download free torrent ) search torrent get torrent and add u torrent download u r new free version
Aug 13, 2013 | Corel DRAW Graphics Suite 12
I need the activation code for the following serial number for corel draw X4 DR14T22-FKTH7SJ-KN3CTHP-5BED2VW
corel draw x4 crack
change the date 2010 to 2009
the install the corel draw x4
download the keygen from
extract the zip file of keygen
open the 'corel draw x4 keygen' folder
open x4 keygen
in keygen press 'key code' button and copy the serial no.
then open the corel draw x4. paste the serial no. (ctrl+v).
click on the phone corel and copy the installation code and go to keygen and paste the installation code then click generate button and copy the activation code the go to corel darw and paste it the click finish
Jul 19, 2011 | CorelDRAW Graphics Suite X4 for PC...
I try to reinstal corel draw graphic 11 but it's always fail.. please guide me. i use windows 7
-Try to remove your older corel draw in control panel
-Delete folder corel draw in program files
-Restart computer
-Try to install corel draw again, Thx
May 31, 2011 | CorelDraw Graphics Suite 11 for Mac, PC
I am not able to install Corel Draw X5, after entering the serial key, it seems to install for about 45 mins and then ends up with """Your system has not been modified. To complete...
You may have a corrupted install. Check the control panel to see if Corel Draw installed. You can use the "uninstall software" from the control panel. then once uninstalled, try re-installing. Before doing all this I would reboot your computer.
Nov 04, 2017 | Corel DRAW Graphics Suite X5
I have used CorelDraw 8 for years, and the clipart worked fine, even with Windows XP, but I installed CorelDraw X4 and installed it. But after Installing CorelDraw X4, I could no longer is CorelDraw 8...
I had a similar problem with Coreldraw 8. I used it successfully for years and loved it on varoius version of Windows, currently XP. I installed Coreldraw 12 and still had Corel 8 on the computer.
Now the problem: Corel 8 and Corel 12 could not open the Corel 8 clipart disk #2, only just down to the folder level. When I right clicked on the Corel 8 disk #2 clipart folder and checked the Path Properties it gave me a path other than the correct clipart disk location (in my case it should have read E:) BUT it was some weird location like
MNfisherman referenced above and read: C:\Documents and Settings\All Users\Documents\Corel.! What the?! I knew the path should have read E: to access the clipart since the clipart was on the disk and in my CD tray, so I uninstalled Corel 12 thinking that was the problem since 8 had worked fine, then checked the clipart CD again but still no luck.
I then uinstalled Corel 8, so now I had no Corel program on hard drive. I put the Corel 8 clipart disk #2 in the computer knowing it would not open the clips but just to see if I could get beyond the folder level to see if the clipart files were there and yes I could. (I could only read the names of the files at this point because no Corel on computer) So I only reinstalled Coreldraw 12 figuring the later version would open the older version clipart and Success! It worked. I think my problem had something to do with the Corel 8 MF indexer, but I'm not sure. I had a red semi circle (like the Corel Set Up Semi circle) on all of the clipart folders instead of the regular yellowish fold so thats why I think it had something to do with indexer or other type of setup conflict). Now all of my clipart folders appear normal being the regular yellowish color folder.
I suggest using a clean slate by unistalling all versions (Make sure you shut down the computer after each uninstall to get rid of all of the components of the program and then restart the computer) and then only reinstall the newest version. Hope this helps. Good Luck
Oct 15, 2010 | Corel Draw 8
Corel draw graphic suite 12 serial number
corel draw grphics suit 12.0 serial no.
Sep 08, 2010 | Corel DRAW Graphics Suite 12
Computer keeps trying to install WordPerfect Office 12
It may be in your programs that you need to uninstall WordPerfect Office 12. It just seems like something is partially installed and wants to complete.
Jan 10, 2009 | Corel WordPerfect Office 12 Standard...
Corel AE CorelDRAW Graphics Suite 12 for PC Logo
63 people viewed this question
Top Corel Computers & Internet Experts
Martin Murray
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
