Question about Brother MFC-845CW multi-function All-In-One InkJet Printer
Brother MFC 845 CW Paper Jam
My brother mfc 845cw had a paper jam. After, I got the paper out the machine it would not work anymore. The screen continued to say paper jam. I kept thinking there must be some little piece of paper somewhere that I was unable to see. However, I couldn't ever find any more paper stuck anywhere. I went to Brothers website and tried the solutions they had and nothing worked. I had a different model Brother before. So, i made sure each time i opened and closed all the other compartments. There was one thing I did read about putting the black back cover in wrong, that it can mess something up?? maybe a sensor? I did put it in wrong,upside down or something for a minute
and realized it was not fitting. So, I pulled it out and put it in the correct way. Could this be the problem? And, if so can it be fixed? and how? Thanks, Serenity 2007
  • 4 more comments
  • Anonymous Mar 27, 2008
    I also encountered a paper jam and followed instructions about how to remove it. Each time, when I pulled the stuck paper from the back as instructed, a little corner on the left side (when viewed facing the back) would tear off and I'd have to remove it separately. I'd open the whole cover as instructed and close. The paper jam display would go away...yet each time I try to print or copy now, the same jam occurs along with a horrible grinding sound as the rollers try to advance the paper unsuccessfully. I too think there may be a tiny shred of paper still stuck in there causing this...or maybe something on the left side of the roller is malfunctioning? I would hate to take this to the repair shop since the repair would probably cost more than I paid for the machine in the first place. Any ideas? Thanks...Carol
  • Anonymous Sep 13, 2008
    same problem - there's no error code, just "paper jam" - though I was able to remove the paper entirely. Please help...
  • cathlynd Oct 02, 2008
    Unable to print 50 after clearing out paper jam- help!
  • Anonymous Oct 24, 2008
    paper jam on screen
  • Anonymous Jan 07, 2009
    HELLLP! I have the same problem. there are no error codes
  • maceng Jan 19, 2009
    Unable to print 30 and 50
    Can't u read?
The problem may not be an actual paper jam. If it makes 2 grinding noises after you plug it in and it resets, or after you lift the top portion and set it back down, that means the gears that should pull in the paper are not being engaged. There is apparently damage to some gear (usually nylon) in the machine. Unfortunately, I have no way to get into it to examine the exact location of the damage. They built it in almost one piece. But there is a design or manufactring defect in this model which rips an internal gear. Repair costs more than a new model MFC-490CW. If I had a repair manual I could fix the old one.
MK
Posted on Aug 11, 2009
  • 832 Answers
Which two digit error code does the machine display despite paperjam?
Posted on Mar 25, 2008
Just fixed my Brother MFC 845 CW. I had a paper jam and even though I thought I got all the paper out, there was a small piece stuck over on left corner. I unplugged the machine and then I opened up the cover (under the scanner). There was a black box covering the area. Through tinkering I discovered that you can push this to the right and bingo, you can reach any little pieces of paper caught up in there with needle nose pliers, and I had several. Close cover, replace back and it works great now.
Posted on Jun 12, 2013
How to remove jammed paper from brother printer model mfc 845cw how
Open the Cover of the Printer and Remove the Cartridge from the Printer After you can remove the jammed paper from the printer.
Jun 28, 2014 | Brother Multi-Function Center MFC-240C...
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
I have a message on my display screen that says "unable to print 36" What does that mean and how do I fix it?
36 usually means that a paper is jammed. You will have to open it up and manually remove the paper.
Mar 22, 2011 | Brother MFC-845CW multi-function...
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
I have a Brother MFC-885 that shows paper jam although all paper has been removed What do I do please?
Common problem. Open the back door and check the sensor flag and make sure it flips back and forth freely. Check the spring. Also check inside the drum cavity ares for same flags.
Dec 30, 2009 | Brother MFC-845CW multi-function...
Brothers error message 50
Check for remaining ( small peace) jammed paper inside.
Jan 23, 2009 | Brother MFC-3240C All-In-One InkJet...
Error messages
I can't help directly but if you go here to the (Australian) support site
http://www.brother.com.au/customersupport/customersupport.asp
you may find your answer.
Note You may need to contact them direct to get your answer.
Good luck.
May 11, 2008 | Brother Multi-Function Center MFC-240C...
Error messages
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
Dec 29, 2007 | Brother MFC-845CW multi-function...
Brother MFC-845CW multi-function All-In-One InkJet Printer Logo
641 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
