Question about NEC AccuSync 90 19 in.CRT Conventional Monitor
Accusync90 continues to burn out q505 (SCR), and Q504 (Horiz output). All this happened after the curcuit was shorted to ground by the support bracket that is under the center of the chassie. The short also burned that a hole through the board, I replaced six other componets by copying from another accusync 90 and had to straight wire the burned traces. This seems to be a design problem as the other was had shorted in the same place. I was able to repair that one. NO schematic available.
Horiz deflectiion bad
if the transistor gets very hot in under 30 seconds the problem is in the driver circuit in front of it--open or off value cap is most common. 5 minutes is waiting too long---touch the face of transistor--can be mildly warm but not HOT.
Apr 10, 2012 | Televison & Video
I have two Sony KV-27FS120, they have the same problem, 4 blink, both have no vertical & horizontal drive from IC001 jungle chip, and Q505 horiz output blow. Circuits between them look good. I replace...
Check very carefully for cold solders on horiz. drive transformer also replace the electrolytic cap that shapes the horiz. drive signal - if you have a scope and manual compare the drive signal shape.
Some times using poor after market horiz o/p's also causes the problem - does the o/p heatsink get to hot to touch or does the horiz o/p blow immeadiatly?
Oct 19, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
How do I repair my television. It is a rear
sounds like your horiz output transformer is shorting out
Oct 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
When we turn on the TV it goes to standby and will not change
Switch mode power supply is shutting it down,,this is a protection mode and standby light shows it is still working,,most likley it has a horiz sweep failure,,if you know how I would check the Horiz output to see if it is shorted,,if so replace and if you have equipment bring it up at around 80 volts and see if current is excessive ,if it is you possible have a horiz sweep transformer gone bad, this is most likley problem but could be somthing else but this is where I would start,,35 years experenice in this field and today I despise working on big screens,,kinda burnt out .You might also note that the tubes have not leaked onto the board as there is some models done this,,you will see corrision on boards if this has happened
From Wendell
Aug 04, 2009 | Sony KP-61V90 61" Rear Projection...
RCA Guide Plus Gold Gemstar
The set tries 3 times to come on (3 blinks) if there a problem such as a short, it will cycle without turning on. Unfortunately your set is notorious for having bad flyback transformers. Most likely the horizontal output transistor is shorted as well. Common causes for your symptom are: LL05 (horiz out transformer) RCA part# 257805; TL 02 ( horiz output transistor) 2SC5148; and open connections on the printed circuit board at LL 04 and L14401 (coils) all of which can cause the horizontal output transistor to be shorted.
Nov 25, 2007 | RCA F32450 32" TV
Sony KV-32S25 32"
Check Horiz. output transistor = shorted?
1)replace with first quality transistor
2)solder horiz driver circuitry
3)replace shorted converter transistors (2SC4834)
4)Replace open R607 .1 ohm 1/2 w.fusible (resistor ok)
Oct 25, 2007 | Sony KV-32S25 32" TV
Tv trouble shooting
1)Check secondary fuse devices. 2)Check horiz output xistor=shorted? 3)replace w/equiv.or better part. 4)Check solder connects in horiz drive circuit. Replace small electrolytic filter cap in base circuit of horiz o/p==horiz drive xformer and xistor area,typically 1mf/160v,C531? 2b)not shorted==do step 4 anyway 5)still blinking?==check vert o/p,audio o/p and regulated o/p's
Oct 02, 2007 | JVC AV-A21M3U 21" TV
Standby timer light blinking, tv will not turn on
Check out Ceramic Capacitor C514 by the horiz. output transistor (burned/shorted?) My question is how do you find the specs of the capacitor and where do you buy one?
Dec 11, 2006 | Sony KP-53S65 53" Rear Projection...
Part number
oh an easy one LOL That part # is 1-453-268-21 and available at at a price of $82.12. One thing though Make sure you check the horizontal output transistor with all the leads disconnected from the curcuit as this part sometimes goes bad when the fly does. My regular practice with any flyback replacement is to automaticly replace the HOT(horiz. output transistor) as well as resoldering the hhorizontal driver transformer and the horiz. driver transistor. Hope this assist yout repair and makes a happy one. Thats what were here for! Good Luck.
Apr 18, 2006 | Sony KV-27S42 27" TV
NEC AccuSync 90 19 in.CRT Conventional Monitor Logo
110 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
