Question about HP Photosmart C5180 All-In-One InkJet Printer
My scanner won't do anything but blink after I press the scan button. No windows pop up for me to accept nor do the scanned item go to pictures folder like it's supposed to.
    Guru:
  • 324 Answers
You will need to reinstall the drivers to get the pop up,
regards
Posted on Apr 30, 2010
HP Deskjet f4435 will print, but won't scan. Orange light blinks
When I press the scanner button the top power button starts blinking but the machine does not scan. I have not used the scanning function on this machine before. Please help...you may need to reinstall your ..
Aug 16, 2011 | HP DeskJet F380 All-In-One Printer
I DONT KNOW HOW THE SCANNER WORKS.WHERE TO INSERT THE PICTURE I WANT TO SCAN.
Which device do you have? If it is an all-in-one that does not have an automatic document feeder (ADF), you lift up the scanner cover and place your photo face down on the glass. If there is an ADF, place the document face up in the feeder. (Using the ADF is not recommended for pictures.)
If it is a stand-alone scanner, the cover is more obvious. For single-sheet scanners, check the manual for which side of the document needs to be forward.
Depending on the OS and software installed, you launch your scan program and adjust the resolution and destination and press scan. (If you have an all-in-one, you may need to install the manufacturer's full-featured software first. Otherwise you will only get printing enabled.) If you use a generic OS driver, the buttons on the unit will not trigger the computer responding to the commands.
Set the destinations for scanner buttons in the software before using the unit buttons when using the full-featured software. Check the manual for specific information. The button presses are noticed by a monitoring program. If that isn't running the unit buttons will not work.
I hope this helps.
(Windows XP, Vista and Win7 all accept scans in Paint (File > Import from Camera or Scanner > New Scan). Vista and Win7 also have Windows Fax and Scan that can acquire scans.)
Sep 14, 2010 | Office Equipment & Supplies
How do i scan using a HP desktop F380
Deskjet F380 features a scanner within the upper portion of the device. "Scanning" an item describes the electronic process of converting pictures or text to data, then transferring that data to the computer as an image. Scanning an item into the computer is a simple task with the F380, the only limitation is the size of the item,
follow the steps below
Step 1
Turn the unit on by pressing the "On" button located at the top control panel. The control panel is located on the left side of the unit. The "On" button will illuminate to indicate that the unit is receiving power.
  • Step 2 Load the scanner with the item to be scanned. First, lift the lid of the F380 to the upright position to reveal the scanning surface. Place the item to be scanned face down onto the scanning surface. Position the item so that the edge of the item rests squarely against the front left-hand corner of the scanning surface, then close the unit's lid.
  • Step 3 Press the "Scan" button located at the lower left-hand corner of the F350's control panel to start the scan. If necessary, the scanning process can be stopped by pressing the "Cancel" button located just to the left of the "X" on the control panel.
  • Step 4 Save the scanned image to the computer when the scan is complete by clicking the "Accept" button on the window that appears on the computer's monitor.
  • Dec 29, 2009 | HP DeskJet F380 All-In-One Printer
    Dell 810 all in one printer/scanner not scanning
    scanning is a bit of a trick. You have to have hardware to scan with, and SOFTWARE to receive images. Make sure the scanners imaging software suite has been installed, OR, you can use the scanner manager in windows to scan with. Just select the dell 810 as the "scanner source" and click "scan". that should do it.
    Oct 26, 2009 | Dell 810 All-In-One InkJet Printer
    How to Scan a Picture onto the Computer
    turn the printer on, place the picture on the glass, on the printer under mode press the big silver button until the scan light comes on  then press select, you should hear the picture scanning, then on the computer, go under my pictures and you should see that picture.
    Apr 16, 2009 | Lexmark P4350 All-In-One InkJet Printer
    Cannot scan from Lexmark printer onto laptop
    As a work around try installing Windows fax and scan and using that program to scan your items - I have multiple printers and it works great for me
    Aug 10, 2017 | Lexmark X3470 All-In-One InkJet Printer
    Still looking for Smart-Scan software
    You can program the scan button by going to "Control Panel" and "Scanner's and Camera's.
    Right Click the scanner and go to "Properties"
    Select the "Events" tab
    It should allow you to program your one touch button from here. I just wanna verify that you do have the CX3200 and not a Stylus Scan 2500?
    Aug 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Scanner
    Reinstall you software for the scanner .
    http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1849438&taskId=135&prodTypeId=15179&pro
    Jul 23, 2008 | HP Scanjet G3010 Flatbed Scanner
    Scanner Problem
    Perform a clean and "No bloated" installation of the hardware.
    Uninstall ALL the HP printer software, disconnect the PSC and reboot the computer.
    When windows finish to load, connect the PSC again, the new hardware wizard will show up, follow the instructions with the HP Installation disk in the drive.
    IMPORTANT: When a silver sand glass show up in the screen, CANCEL the installation of the HP software (this is by clicking "CANCEL" button or by no accepting the license terms). This will install only the PSC Drivers and nothing else.
    Use a TWAIN compatible program (Windows imaging, photoshop, paint shop pro) and try scanning again.
    Jan 27, 2008 | HP PSC 1510 All-In-One InkJet Printer
    Scanner, scans and then re-scans.
    you can go direct open my computer then you will find in the my computer window icon for HP officejet 4300 if you press it you can go ahead with wizard that let you scan your photo or document fast you can even send short cut to this icon at the desktop so you can reach it faster
     OR   ~~~~~~  another solution
    when you open the hp software press the scan botton then will open another window has two option choos scan and then choos scan again in the other window
    Please rate me if this solution was ok thank you
    Oct 15, 2007 | HP PSC 1315 All-In-One InkJet Printer
    HP Photosmart C5180 All-In-One InkJet Printer Logo
    78 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
