Question about KitchenAid KGST307 Gas Kitchen Range
Oven will not lite - KitchenAid KGST307 Gas Kitchen Range
  • 713 Answers
Hi,the problem is definately from the gas valve/regulator,its bad and needs to be replaced,here is how you go about with the diagnosis and replacement of the gas valve/regulator .
Remove the bottom drawer. Locate the gas valve/regulator with three electrical solenoids terminals on the back of the range. The middle terminal is Common, the upper terminal is Broil and the bottom terminal is Bake. Mark all wires and remove them from the terminals. Check between each solenoid for 216 Ohms resistance (Broil to Common and Bake to Common). If one of the solenoid is defective, neither one will operate and the gas valve/regulator has to be replaced.
This part is not too difficult to replace yourself if you know how to handle a simple tools. Pull the range out of the wall and shut off the gas. Before you'll remove the wires from the valve/regulator draw a picture of them so you will know where to put them on the new part. Tight all gas line connectors to prevent possible gas leak. Ensure to check all connections with a gas leak detector to make sure everything is safe.
You are done with the fix and the problem is solved.
thanks and take care
Posted on Apr 30, 2010
Gas double oven will not lite
You may not have given it enough time to purge all the air from the supply line.
Aug 17, 2012 | Jenn-Air JMW9130D Double Oven
MY SUBURBAN OVEN PILOT LITES, BUT WHEN i RELEASE KNOB PILOT GOES OUT AND OVEN WONT LITE. i REPLACED SAFETY VALVE BUT STILL SAME PROBLEM.
the polit light lights but when you let the nob go for the oven burner to come on the polit light goes out
Sep 22, 2011 | Ovens
Can not get this pilot lite lite in the broiler
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 30, 2011 | Magic Chef Microwave Ovens
How do I lite the oven pilot.
Sorry to read about your problem, I hope this helps you out.
most new oven's, gas or electric you do not lite....you may have a defective unit....
if its real old, you oven knob should say pilot...if not you have a newer oven...
then you have a defective pilot system
Dec 25, 2010 | Ovens
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Pilot lite for the oven need it located
If you remove the bottom panel inside the oven you will see pilot and burner that heats the oven.
Jan 01, 2009 | Hotpoint RGA520 Gas Kitchen Range
Changed the lite bulb on ge double ge eletric oven and it blew
There is no reset switch on the oven you blew the breaker in the control panel. you will have to find it and flip it.
Dec 21, 2008 | GE Profile JTP56 Electric Double Oven
Oven will not lite
Unplug the unit, change the igniter maybe it does not draw enough ampage.
or check the gas control knob if somebody mistakenly turned it to off position. the ON position should be inline with the gas pipe.
Dec 18, 2008 | Frigidaire FGB24S5A Gas Single Oven
KitchenAid KGST307 Gas Kitchen Range Logo
78 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
