My riding mower starts up but does not change grear into drive or reverse.
  • eric527 May 04, 2010
    I have yardman ridingmower it starts up but does not go in reverse or forward. I was given a solution and it does work.I now have squealing and something that smells like a belt is burning.Please help.
    Top Expert:
  • Computers & ... Master
  • 75,822 Answers
U need to turn the mower on it's side and see what is locking up the belt, that is what the noise is, the other solution would be the belt is very loose from age and needs to be replaced, so check that as well.
Posted on May 04, 2010
    Genius:
  • 1,354 Answers
1) started up my mower for the spring and it was working fine and then died. I changed the spark plug, got new gas, jumped it and it starts fine. Well it starts good but it wont move now. The only thing I did was pull out the latch to make it easier to push and put it back in. Now the thing wont go into any gear. Whats the problem? Belt looks a little old but fine and connected to all the pully wheels. 2) I am assuming it is an automatic transmission. Are you sure that you got the latch back into the right position? Out for pushing and in for driving. The other thing to do is to purge the transmission.
Disengage the transmission. Latch out.
With the engine running slow in neutral let the clutch out, move the shift lever to full forward for five seconds then to full reverserse for 5 seconds. Do this three times.
Turn off the engine and engage the transmission, latch in.
With the engine running 1/2 speed and in neutral disengage the clutch.
Slowly move the shift lever to forward and move about 5 feet, slowly move the shift lever to reverse and move about 5 feet, return shift lever to neutral, repeat 3 times.
This will purge the transmission.
Hope this helps.
Also, make sure that the drive belt is turning the transmission pulley.
Posted on Apr 30, 2010
Troubleshooting lt2000 craftsman riding mower
it could be but if it kept going with the clutch in i would guess the belt is the wrong one or it was put on incorrectly. not saying you don't know what you are doing but it happens a lot where the belt was routed wrong and did the same thing you are saying. be sure it is routed correctly.
Jun 20, 2016 | Craftsman Garden
Is there a solution for forward and reverse selector not functioning?
Make sure the trans axle free wheel lever is in the drive position
Oct 13, 2015 | Husqvarna Garden
Mower will not go into drive or reverse White riding mower
bad hdro pump but first try and change hydro oil and filter sometimes it works
Jul 06, 2014 | Mtd LAWN MOWER PART # 683-04163B FRAME...
I have a snapper model 3311XS mower that will not go into reverse. How do i fix it?
need to take it to a repair shop or if you know how to take it apart to fix it
Jul 04, 2014 | Snapper Garden
Replaced drivebelt on troybilt riding mower now the forward pedal moves mower in reverse?
Sounds like you have the belt running in the opposite direction. You need to Change the way the belt is routed around the pulleys
Jun 18, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
My Weedeater riding lawn mower will not move when it is in drive or reverse
Check your drive belt that it has not slipped off the drive cog under the motor. Also check the alignment of the motor with the handle on the right side (speed, reverse, and neutral lever).. This lever tilts the engine to engage the drive belt.. there is no transmission in this machine.. just how the belt engages by its angle when you push the lever forward and backward.. If the engine is running, it must be either the belt to drive the unit or the angle has been messed up somehow..
Apr 21, 2013 | Weed Eater Weedeater 26" Riding Mower
My Weedeater riding lawn mower will not move in forward or reverse after it has started
Check your drive belt that it has not slipped off.. also check your drive lever on the right side (speeds, neutral, and reverse). The mower uses this lever to angle the motor against the belt to move it..
It is most likely the belt or the angle misaligned if the engine is turning...
Mower starts but will not go it is a lt1040
the mower deck and the drive system each use there own belt check your belts
Aug 07, 2012 | Cub Cadet Garden
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
